Sorry if this has been covered already. I mainly wanted to clear up the process of bringing a R34 GT-T into NSW from QLD.
From what I have read R34s should have been complied with a SEVS plate/sticker.
So to bring a QLD registered R34 into NSW, the SEVS compliance should still hold/be valid for the RTA and I only have to go get a blue slip and the usual RTA rego fee and CTP greenslip?
Is it possible for an R34 to have been complied under any other different methods that might cause issues with RTA ? and is there anything else I have missed?
I live in far north coast NSW so it would be easier for me to look at cars in goldy/brissy than to do a trip down to Sydney.
https://www.sau.com.au/forums/topic/282584-process-qld-to-nsw-rego-r34-gt-t/
yep 100% correct. get the car with the QLD rego. bring it to NSW. take it to a place that does blueslips. it will be good if you have the original compliance paperwork (consumer info papers, import approval etc) but you may be ok without it. after blueslip purchase a CTP green slip, then take both to the RTA and you are good to go...unless you get pinged for a vehicle identity check, if that happens you just have to make an appointment and go there so they can check numbers match etc. then back to the RTA and finish off your rego. :banana:
  • 4 weeks later...
Does the vehicle identity check only cover checking that records match, or do they look at other aspects of the car also? I'm looking at moving back to NSW and my car was originally complied and rego'd in QLD, I've had a Engineers Mod Plate issued for a turbo conversion, I just don't want to run into problems with tfring back.. I don't have the time/parts/money to be reverting a car to stock and all :S
I've read some stories where people just followed the above and all was good, and others where once they had to have an ID Check done they got pulled up for numerous things.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
