Duncan Posted August 13, 2009 Share Posted August 13, 2009 don't worry too much.....its just steel it can be cleaned up and welded Link to comment https://www.sau.com.au/forums/topic/282590-oops-ripped-hicas-out-of-rear-subframe/page/2/#findComment-4766565 Share on other sites More sharing options...
M I K E Posted August 13, 2009 Share Posted August 13, 2009 just to add a little to what Ben has already posted, - none of the R32, R33 or R34 range shares the same part number. - none of the S13, S14 or S15 range shares the same part number. - A31 cefiro is also no good. - Z32 300ZX no good either. - autech stagea rear cradle number is 55400 - 0V600 i also check a few of the other jap nissans, like C34, C33, A32, Y34, Y33 etc and got no joy there either. i wouldn't completely write them off though, the part numbers could just mean minor variations and not that they won't bolt up at all if you have time, test some different ones out and let us know this is an s15 rear cradle in a rwd s2 (i'd imagine cradle mounting points would be identicle on all wc34's so should fit them all) they are meant to be ~50mm narrower than auto stag rear cradles (so similar width to 260rs cradle) but i'll get a mate to do some quick meausrements at his work if he has time (import wreckers) and post up what he finds between cradles if he can. keeping in mind a narrower cradle will need shorter half shafts and prob s14/15 swaybar too like i said earlier, this is my own research so don't take my word - look into it yourself before you go buying anything. i plan to try out the s14/15 rear cradle for myself at the end of the year Link to comment https://www.sau.com.au/forums/topic/282590-oops-ripped-hicas-out-of-rear-subframe/page/2/#findComment-4766648 Share on other sites More sharing options...
BensDR30 Posted August 13, 2009 Share Posted August 13, 2009 I agree, although the part numbers aren't common, I'll bet that there are several that are interchangeable. Further research is definitely required. Link to comment https://www.sau.com.au/forums/topic/282590-oops-ripped-hicas-out-of-rear-subframe/page/2/#findComment-4766840 Share on other sites More sharing options...
KiwiRS4T Posted August 13, 2009 Share Posted August 13, 2009 I sold a Stagea subframe to a guy wanting a wider track in a 180 (is that an S15?) so I would guess that an S15 would be no good. I suspect that any other Stagea subframe would do (pay to have a look and take a few measurements) but still vote for the weld/repair. Link to comment https://www.sau.com.au/forums/topic/282590-oops-ripped-hicas-out-of-rear-subframe/page/2/#findComment-4767087 Share on other sites More sharing options...
M I K E Posted August 14, 2009 Share Posted August 14, 2009 I sold a Stagea subframe to a guy wanting a wider track in a 180 (is that an S15?) so I would guess that an S15 would be no good. I suspect that any other Stagea subframe would do (pay to have a look and take a few measurements) but still vote for the weld/repair. s15 is no good? the pic i posted up there IS an s15 subframe. the bloke you sold yours to would have needed offset bushes for the stag frame to bolt up to his s13 chassis, the same as you need when fitting an s14/15 frame into s13 (because s14/15 and wc34 have the same mounting points) most of you would probably remember grant? here is his first hand experience of fitting an s14 subframe into his stagea http://www.skylinesaustralia.com/forums/Sp...ng-t216144.html Link to comment https://www.sau.com.au/forums/topic/282590-oops-ripped-hicas-out-of-rear-subframe/page/2/#findComment-4767434 Share on other sites More sharing options...
RBPOWA-(TJ) Posted August 14, 2009 Share Posted August 14, 2009 this might help, little example first. off topic. i have severe strut tower rust. i email a few restoration joints with pics, even went into a few, and they all said they couldn't help, but yet they deal with cars that have about 95%rust all over then i took it to my stepfathers mates work shop. got him to have a look, bang gave me a set price for minor and worst case. . . and is happy to give it a crack. should be going in towards end of the month. 35yrs on the job and still going, must be doing a good job at that he might be worth giving a ring, just to see if he would consider fixing a subframe. Phone: (03) 9701 6098 | Address: 78 Popes Road Town: Keysborough (south east Melbourne) Link to comment https://www.sau.com.au/forums/topic/282590-oops-ripped-hicas-out-of-rear-subframe/page/2/#findComment-4768273 Share on other sites More sharing options...
xRHETTx Posted August 16, 2009 Author Share Posted August 16, 2009 thanks for everyone's help... Fortunately Chasers in West Melbourne did a great job and managed to repair the subframe on the car, saving me a whole heap of money and effort. Car drives so much better now. Will still be fitting the new bilsteins and whiteline bushes when I get a chance though. :-) Link to comment https://www.sau.com.au/forums/topic/282590-oops-ripped-hicas-out-of-rear-subframe/page/2/#findComment-4771016 Share on other sites More sharing options...
RBPOWA-(TJ) Posted August 16, 2009 Share Posted August 16, 2009 good stuff! Link to comment https://www.sau.com.au/forums/topic/282590-oops-ripped-hicas-out-of-rear-subframe/page/2/#findComment-4771098 Share on other sites More sharing options...
