Hey guys,
what's the best air intake part to get?
I've been looking at Apexi Power intake...
What are your thoughts?
Oh and roughly how much more power does it give the car? And does it use less petrol?
Cheers :rofl:
Edited by macdog
https://www.sau.com.au/forums/topic/282595-air-intake-part/
Do you want to use the stock box with aftermarket panel filter, or pod filter?
With a panel filter, any aftermarket one will flow better than a factory one. K&N or Trust are ones I would use. You can get them off an R34 Skyline, or S15's. They are all the same.
Pod filter, well I like the Blitz Sonic Power intake kit as it has this cool alloy enclosure over the pod filter so should remain legal (I guess...)
https://www.sau.com.au/forums/topic/282595-air-intake-part/#findComment-4757900
Depends where you are located.
In Melb (OP locale), you can have a pod, but nothing else to the intake (piping, FMIC etc).
The pod MUST in a sealed airbox of it is instant defect... which IS enforced.
If you are wanting a pod, look at either;
3A Racing ~$30 (check out the Autosalon comparo for filtration/flow)
Blitz SUS Power ~$280 (Stainless Steel mesh pod which never needs replacing - can be cleaned - doesn't have the greatest filtration and is commonly found on extreme HP setups in Japan - 1000hp+)
Blitz Sonic Power ~$320 (this is a Blitz LM pod with the alloy enclosure to speed up the velocity of the air and make a certain noise)
https://www.sau.com.au/forums/topic/282595-air-intake-part/#findComment-4758744
  • 1 year later...
The pod may fit but the shield would not fit in as the 350z is quite different.
Looks pretty close actually.
That said, it would be an expensive gamble, but I am sure if needed the shield could be "persuaded" to fit.
Dalton, you got anywhere you can try one on to see if it will fit like a retailer/performance shop etc?
https://www.sau.com.au/forums/topic/282595-air-intake-part/#findComment-5455360
whats the performance difference be between the K&N flat panel compared to the pod filter.. i was lucky to get the flat panel one (oil based on with the pink oil) with my m35.
would there be much difference of power other than the throaty noise of the pod. and does anyone know if theyre legal in qld?
https://www.sau.com.au/forums/topic/282595-air-intake-part/#findComment-5456394
You guys have seen the M35 3.5L NA engine bays? They have the extra section removed from the air filter box. I wonder if we can buy that part???
The Powerduct? You can get it anywhere... try Nissan if you want to part with ~$180... or offer one of the V35 guys money for theirs :)
Or you could make your own with single sided adhesive rubber
yes, they plug straight into our airbox (I have one - freebee from a friend)
Edited by iamhe77
https://www.sau.com.au/forums/topic/282595-air-intake-part/#findComment-5456812
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
