Hey guys,
what's the best air intake part to get?
I've been looking at Apexi Power intake...
What are your thoughts?
Oh and roughly how much more power does it give the car? And does it use less petrol?
Cheers :rofl:
Edited by macdog
https://www.sau.com.au/forums/topic/282595-air-intake-part/
Do you want to use the stock box with aftermarket panel filter, or pod filter?
With a panel filter, any aftermarket one will flow better than a factory one. K&N or Trust are ones I would use. You can get them off an R34 Skyline, or S15's. They are all the same.
Pod filter, well I like the Blitz Sonic Power intake kit as it has this cool alloy enclosure over the pod filter so should remain legal (I guess...)
https://www.sau.com.au/forums/topic/282595-air-intake-part/#findComment-4757900
Depends where you are located.
In Melb (OP locale), you can have a pod, but nothing else to the intake (piping, FMIC etc).
The pod MUST in a sealed airbox of it is instant defect... which IS enforced.
If you are wanting a pod, look at either;
3A Racing ~$30 (check out the Autosalon comparo for filtration/flow)
Blitz SUS Power ~$280 (Stainless Steel mesh pod which never needs replacing - can be cleaned - doesn't have the greatest filtration and is commonly found on extreme HP setups in Japan - 1000hp+)
Blitz Sonic Power ~$320 (this is a Blitz LM pod with the alloy enclosure to speed up the velocity of the air and make a certain noise)
https://www.sau.com.au/forums/topic/282595-air-intake-part/#findComment-4758744
  • 1 year later...
The pod may fit but the shield would not fit in as the 350z is quite different.
Looks pretty close actually.
That said, it would be an expensive gamble, but I am sure if needed the shield could be "persuaded" to fit.
Dalton, you got anywhere you can try one on to see if it will fit like a retailer/performance shop etc?
https://www.sau.com.au/forums/topic/282595-air-intake-part/#findComment-5455360
whats the performance difference be between the K&N flat panel compared to the pod filter.. i was lucky to get the flat panel one (oil based on with the pink oil) with my m35.
would there be much difference of power other than the throaty noise of the pod. and does anyone know if theyre legal in qld?
https://www.sau.com.au/forums/topic/282595-air-intake-part/#findComment-5456394
You guys have seen the M35 3.5L NA engine bays? They have the extra section removed from the air filter box. I wonder if we can buy that part???
The Powerduct? You can get it anywhere... try Nissan if you want to part with ~$180... or offer one of the V35 guys money for theirs :)
Or you could make your own with single sided adhesive rubber
yes, they plug straight into our airbox (I have one - freebee from a friend)
Edited by iamhe77
https://www.sau.com.au/forums/topic/282595-air-intake-part/#findComment-5456812
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
