A package of used HKS GT3037S RB20 Kit for sale.
Kit includes a HKS GT3037S Turbo.
Top mount stainless steel extractor.
External wastegate.
Dump pipe.
Asking for $3,700 ono.
Information of turbo::
HKS GT3037 Pro S - 480 PS Output
COMPRESSOR:
-Wheel- 56 Trim - 57.0 Inducer / 76.2 Major
-Housing- 100 Inlet / 50 Outlet - 0.60 A/R
TURBINE:
-Wheel- 84 Trim - 60.0 Major / 55.0 Exducer
-Housing- T3 inlet / External GT-Pro outlet; 0.68, 0.87 A/R
Contact 0423 442 003
https://www.sau.com.au/forums/topic/28260-fs-used-hks-gt3037s-rb20-kit/
He actually has a 3037S, the S has the split type inducer, as in my avatar.
Must ask though, why are you selling so cheap? Is the turbo stuffed.
I noticed it had oil and water lines too???
I have one of these turbos on my car, and it cost me alot more than $3700 all up once you include the cost of oil and water lines, manifold, wastegate and dump. This is a bargain if anyone is in the market for one of these (unless of course its rooted:))
Also, what is the turbine housing AR? it should be stamped on the housing.
The Pro is internal gated and T3 flange, as its not a pro, it will be GT25 flange - not that it makes much difference if you have a manifold to suit.
Perhaps a bit more info about why you are selling, where it came from, condition etc would help?
Will bolt up to an RB25 head as well. So should be a good chance of fitting R33s, though it will pay to be careful and check that on an R33 the wastegate/ or manifold doesnt clash on any negine bay parts.
I would have been intersted about 2 months ago. Also maybe mention of the manifold has any visible signs of cracks that have been repaired?
  • 4 weeks later...
Hello Breber, I have a hr31 sitting at home in perth and am interested in the turbo that you have. I assume that this is roller bearing and in good condition? I am currently out of the country but my brother will look at it for me. Please contact him at [email protected] If ur interested....
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
