  • Replies 236
A front cut x-trail GT goes for around 15k. There was a partially damaged one for 8.5k I saw running around in Japan but needed new bottom end bearings.
Besides, the SR20VET that comes in the GTs doesn't really drop in to my X-trail at all, Its a huuuuuge job... They've got different transfer cases and gearboxes, plus they only came out in a CVT automatic and I don't want that at all.
On top of that, the QR25DE 5sp doesn't bolt up to the SR motor, so a custom bellhousing would be needed ($$$), and there's not a chance in hell of finding a clutch that fits the QR, and input shaft of the SR...
I know for a fact that the SR > non-GT x-trail conversion has never been tried, its almost physically impossible.
But yeh, it'd be amazing if it would work! :D
Thanks for the encouragement ;)
there was a guy around the northern beaches in syd that had a turbo xtrail, thing had a sr20 in it but im pretty sure it was a manual, might have been one of those jap ones, will be a sleeper big time, the 2.5 in them standard isnt exactly a slouch for what it is.
yeh i know theres a guy in sydney with a GT pulls IIRC 211wkw, on 13psi i think. Doubtful it was manual, but i could be wrong.
The QR does pretty good... exhaust and intake, and its up with most bigger cars (commos, falcons etc). Sentras in the US are quick cars, heaps of the done up ones care competing with WRXs and EVOs.
Exhaust tomorro, will post bulk pics.
haha hey man!
yeh she came up well!
got it rebuilt few weeks ago just for kicks.
its had a full once over, it looks pretty dardy now aye, bin on the car for a few days now, spools up good!
Did ya find another turbo for your VL?
haha hey man!
sweet as man,
yeah the t3 i had for it was fine, just ended up being oil return line kinked, i thought the oil seal went on it, but yeah rebuilding bottom end, but shit has come up in life, so planning on selling rolling shelling ready for paint, getting a r32 and chucking rb30 bottomend on it when its rebuilt, so was just passing through and spotted your thread.
take it easy best of luck,
peace.
  • 3 weeks later...
Just wanna give you guys a bit of a sneak peak of the progress.
I gave up trying to do the exhaust myself, so its getting sent off to carline mufflers next friday for the dump and front pipe, the rest is an easy job that i can actually do myself.
Cooler piping's done, oil return is done, vacuum lines and breathers, pretty much everything except the exhaust.
heres some pics:
And yes, before anyone asks, the bumper does fit on with that intercooler piping...
lol i rekon i'd last about 300m on the road before a yellow sticker if i had no exhaust haha
and after all, im not blessed with 6 cyls of heaven sounding RB note, ive got more of an SR sorta sound. So i gotta tone it down a little :)
Yeh its on the road, not tune yet so i just cant go into boost that far yet. starts making boost at about 2.5-3k and prob full boost by 3.5k maybe? not sure...
next vid is an in car one for sure lol
dunno man, prob early in the new year.
i lost my license and get it back on christmas eve. going on holidays after then so soon after i get back.
but the cars all finished minus the tune on the 27th @ hyperdrive.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
