HAY,
CLEANING UP MY SHED AND THESE RIMS ARE JUST TAKING UP ROOM.
ILL HAVE ALOT MORE BITZ AND PIECES POSTED UP IN THE NEXT FEW DAYS SO KEEP AND EYE OUT.
I HAVE SINCE BOUGHT RAYS TE37'S IN BLACK AND ITS A WASTE TO SEE THESE JUST LAYING AROUND COLLECTING DUST.
DISCRIPTION-
ADVAN RG GOLD 17X9.5+14 IN GTR OFFSET.
FITTED WITH BRIDGESTONE RE01-R SEMI TRACK TYRES.
TYRES ARE 255/40/17.
THESE TYRES ARE VERY EXPENSIVE AND VERY GRIPPY! I HAVE ONLY DONE 1 TRACK DAY ON THESE TYRES AND APPROX 2000KLMS STREET DRIVING SO THEY ARE STILL LIKE NEW WITH 90% TREAD LEFT.
THE ADVAN RG'S ARE 2 YEARS OLD AND I BOUGHT THEM BRAND NEW.VERY EXPENSIVE AND THEY ARE VERY STRONG AND LIGHT WEIGHT.
RIMS ARE IN EXELENT CONDITION (SEE PICS) 1 HAS A LITTLE SCRATCH ON THE OUTER RIM BUT U CANT EVEN NOTICE IT.THEY LOOK FAT ON ANY GTR 32,33,34.WILL ALSO FIT 32-R33-34 GTS-T BUT REAR GUARDS HAVE TO BE PULLED OUT A LITTLE.
$2,500 TYRES AND RIMS.
I CAN POST ANYWHERE VIA FASTWAYS COURIERS AT BUYERS EXPENCE OR PICK UP WELCOME.(SOUTHSIDE BRISBANE)
CALL ME ON 0438-167-207 (PREFER PHONE CONTACT.)
PLZ NO STUPID OFFERS, QUALITY RIMS WITH QUALITY TYRES!
ridiculously good price! id consider these for my JZA80 but im already pushing it up front as is with a 9" +15 :D
i totally agree, price is f*kn ridiculusly cheap you could get much more. i bought advan tc2's recently for 2900, with gutter scratches and shitty 50% rubber.
These rims are clean!
good luck with sale
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
