I thought your dent was on the passenger side? lol........ or is there a new one?
My car wont be ready for another month or so....... unless someone wants to lent me some ballin' rims haha
Oh i thought Weezy had it on the left hand side :~
  • Replies 127
Posted Images
  • 1 month later...
Ok guys! Been a while since Ive been online, or updated this thread. Ive been on the phone with the calendar makers and need photos in by end of this month! Ive recieved a fair few, but not alot of great quality ones. So everyone - start geting out in this nice weather and take some photos, send me what you got so i can get this one rolling!
Felpurcell@hotmail.com
Send send!
Send send!
instead of clogging up your email, ill just throw a few on a dvd and drop it off to you or luke at work.
i might go for a casual photoshoot this weekend, ill keep you guys updated.
Let me know if and where you go man,
If I'm not doing anything I'll be down. Get Jarrad out in his fresh white 32-R aswell
Yep good idea! If anyone else wants to do this, let me know.
hey flick, ive always loved this pic, but u have the hi res version obviously lol
Nisskid, good choice :P I still have that in high res, thanks for reminding me. Rekon that will make a great main photo!
Shane - got your pic of the GTR, perfect, Just perfect!
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
