For sale are 2 brand new Continental SportContact3 tyres to suit 17" wheels/rims. Specs are 225/45 R17.
These are the same tyres that BMW fit to their M3s and other high-performing cars. These tyres rate very well on all reviews.
These tyres are brand new, never been used or even fitted to a rim. RRP for these tyres are $325 per tyre.
Take away both tyres for $500 (or best offer). This is WAY below RRP.
Pickup from Carlingford in Sydney, NSW.
Any more info, call or message Rob on 0423 696 517
Taken from a review on these tyres:
Overall rating for ContiSportContactTM 3: "Highly Recommended"
"... Not only is it the fastest tyre on the testing course. At the same time, it handles itself easily and safely. That is how a tyre should be. Terrific on dry surfaces. Best braking performance on wet surface and very good hydroplaning characteristics. Balanced driving behaviour on dry roads..."
    • C34 Stagea RS4S Standard RB25DET Neo with ARP Headstuds and MLSR Gasket. Bosch 1000cc injectors Walbro 460 Standard neo inlet plenum w/rb25 s2 throttle body 6 Boost Low Mount Manifold Turbosmart Gen V 45mm wastegate (recirculated) Pulsar g30-770 (0.72 rear housing) 3.5"intake pipe to clear mounts, 3.5" dump to 3" exhaust Link G4X Ecu 380 hp on 98 octane, 478 HP on e85 (mainline hub dyno) Video of Earlier Run VID_300701109_043404_458.mp4 Final Dyno Sheet:
    • Meh. Every single gear in my gearbox will crunch. I've been treating it nicely for >12 years now.
    • How fast are you doing the downshift? 4th gear was revised multiple times until 1998 to fix this issue. Synchro clips can fall out, synchros can wear. Most likely you're looking at a new transmission unfortunately. If you need to limp it until then double clutch downshifts into 4th.
    • Sorry I was being harsh there, but am I wrong? You can buy a M340i easily, and there's loads available second hand. A lot more workshops modifying them as well. How about getting parts for them? Don't get me wrong, I'd love a 400R, even a 4cyl (I looked at a few V36s before buying my shitbox BMW). Sadly Infiniti died in Aus and we're stuck with importing them as niche vehicles. Supply and demand
    • Probably straight swap for an R32 GT-R? lol
