i have 10.5 on the back with dish and 8.5 on front with no dish and 9.5 have little dish which will look better imo
edit: also i wanna get wide fenders and the 8.5 are inline with stock guards so might look funny
Edited by sxc13
most wider front guards are 25mm wider, meaning you can run what an R32 GTR would run... which i think is +20.. so it will fit yes..
how on earth have you got a 19 x 10.5" under the rear?? have you got pics???... i had 17 x 9.5 and it was near rubbing the rear tie rod and the rim stuck out from the guard. what size tyres are you running?? Bakes's R34 GTR has 19x9.5s and he has stretched 275's on them.
Since when are 275's stretched onto 9.5" rims? I've got 255's on mine and it's hardly a stretch at all.
For the op, mate if you're going wider guards then go for it. Use an offset calculator to work out the best fitment based on your current rims, just try to have them stick out 20-25mm more but with minimal to no lower amount of inner clearance. +20 sounds about right but double check anyway.
I still fail to see why people stick tiny tiny tyres on 10.5" rims....what is the point? 245s should be on an 8" - 8.5" rim not bloody 10.5"!
if your doing it for looks...well 90% of the population will say it looks like arse....
Lol I'd say 90% of the population would say a 245 on an 8 looks like ass.
I'm a fan of MILD stretch myself. Like 245 on a 9.5 looks about right depending on brand and type IMO. Less sidewall flex too.
ok,
1: 245's arent a tiny tyre
2: the point is looks, tyre availability, tyre price, reducing sidewall flex, increasing tyre response
3: 245's on a 8" will feel like shit as soon as u go around corner unless the sidewalls are rock hard, some people enjoy going around corners, not just straight line.
4: tyre width can be sacraficed to allow for the higher quality tyre, which ultimately will provide better performance
5: since when the f**k did we as car enthusiasts give a shit about what 90% of the population thinks?
sounds like u need to have a hard look at who u build ur car for, urself or 90% of the population. if it's the latter then i think it's time for you to move on and sell ur skyline.
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
