okies well i have a set of near new hsd tt's with around 1000km on them cost me $1399 from otomoto so they should still have warranty on them for 12 months.
and a set of tein HRs with the extra slave springs in them, the teins have one blown coil over from the rear so could do with some love and attention the other 3 are fine.
i am after $1500 for both sets pick up from brookvale can ship at buyers expense.
they are to suit a r33 skyline
prefer not to separate.
TT TYPE COILOVERS
The new TT type coilovers from HSD have been designed with every-day driving comfort as a priority. They use a twin-tube damper design (hence ‘TT’) which is less aggressive than the large-diameter mono-tube type dampers in the HR series. Spring rates are also generally 20-30% softer than the race-oriented HR series. In most cases the top mounting plate features a rubber bushing to reduce noise and harshness, but for strut replacements a camber-adjustable pillow-ball top is used for a larger range of camber adjustment.
Like the HR series the new TT uses an adjustable base bracket for easy height adjustment. The dampers also feature a 12-step adjuster for damping force. For a low-key appearance the aluminium lock rings and top plates are anodised grey, with black springs and brackets. The spring rates listed are our standard specifications. Alternative springs are available to order.
https://www.sau.com.au/forums/topic/282690-tein-hsd-coil-overs-to-go/
the teins i am not to sure, they have the slave springs under the standard coil.
the hsd i think are 6kg nice for the street
hsds have done around 1000KM teins i am not to sure as they were in the car when i bought it but would not hurt for a service on them maybe.
i will get pics up tonight for you.
they are good quality and they have a nice smooth ride but i changed my plan for the car and am now after a firmer coil over for track / drift
people have said change springs but i want another set of bc's as i had therm in my last track day car and i have already done all the home work with them so it is easier for me.
and the teins came out of it when i did the hsd's so that is why i have them.
MIdnight_33 :
i will give ya $600 posted to vic
HAHAHAHAHAHAHAHAHAHA YOUR SO FUNNY YOU ARE LIKE OMG SO FUNNY 600 FOR BRAND NEW COIL OVER THAT COST ME 1300 JUST AVER A WEEK AGO HAHAHAHA OM MAN I HAVE A STITCH FROM LAUGHING SO HARD.
NO LOW BALL THANKS.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
