Hi All,
Just purchased a 1999 RS4 in grey with 62000 on the clock. Pretty impressed with the car so far besides the fact that I didnt get one with leather and a sun roof! :banana:
I have 2 questions (I couldnt find the answer in a search)...
1. Can somebody please post a pic of the location of the rear TV tuner with the RCA Inputs (for the Xanavi head unit) - I spent 30 minutes ripping the boot trimmings out before giving up!
2. Has anybody retro fitted HID lights into the S2 housing? I know the Xeonon lights are removed during compliance but they dont seem to have the projectors which HID lights use right?
Also want to mention that there was heaps of useful infomation on there forums which infulenced me to get the stagea - so far I havent been disappointed!
Adrian.
https://www.sau.com.au/forums/topic/282730-got-a-stag-and-few-questions/
gday mate
ur after a h1 HID drop in kit for you lights. i recomend 6000k for street every day driving.. just so you dont get pulled up by cops.
my rca's were crammed in behind the ECU (passenger foot well on the right behind that kickpanel)
chef.
hi adrian, what neck of the woods do you hail from?
if you look in the for sale section you will see that adam (chef_stagea) is selling a full leather interior so you need not worry about missing out on buying a car with it - just snap his up!
i don't have xanavi in mine, but i believe it is in the drivers side trim in the boot
and you can buy plenty of aftermarket HID kits that will drop straight into the standard headlight housings, alternatively buy a set of factory xenons that aren't modified and swap them in
actually youll be after a D2R 'kit' as you said they were already removed for compliance. just remove the H1 'converter' and replace the wiring. its entirely possible that they left the ballast there and all the wiring so you might only need to buy a paur of burners and put them in!
hey guys thanks for the feedback...im getting mixed messages about the tuner inputs so ill check the drivers side boot and passenger footwell this weekend, its really startung to shit me i cant find it!!
I retro fitted HID's into my old bmw e36 but that had the ballast (circular glass bit inside the headlamp to get the cutoff so oncoming traffic is not blinded)... Dont you need those bits? Anybody got a pic of their HID setup??
BTW im from Sydney area.
truth be known man there isnt much to see in a pic. i stashed my balasts in the front 1/4 panel. then on the side of the headlight where they go stock. a good douible sided tape will do the job. trust me get a h1 kit. cheap and easy to do. just cut the wiring job compliance did... posative negative... mount the balast. and plug in the globe. its easy as. no f**kin with fuses/relays they may have played with... mine were no chance of revival. me and kidafa are in syd for a day mon the 15th if u really need help lol.
leather to syd may be an option soon if i find a jet ski. (will drive over to get it) leave that for pm tho :P
leather to syd may be an option soon if i find a jet ski. (will drive over to get it) leave that for pm tho :(
sorry guys im a retard - Im referring to the projector NOT ballast - as mentioned before Ive retrofitted them in my old car and its really easy... Im only concerned about the factory headlight not having a HID projector which will direct the light (for the oncoming traffic)!!
In regards to the leather seats i ill pass 4 now - they look good and all as funds are limited (babys on the way) I would really like to sort out the handling side of things ... thinking to source some eibach springs which i heard are pretty smooth
nooooo!!\
in all honesty, keep stock springs
it'd be shock bodies you'd be after, ie Bilstein struts.
Bilstein shocks with stock springs and Whiteline swaybars / bushes -= massive f**ken win
glhf with bubs, nice 1
Second what Tangles said about the suspension. I've got the full suspension upgrade with the standard springs and its great. Its firm, yet still compliant enough. The adjustment on the Bilsteins helps to get the ride height spot on. Its good.
If your mileage is anywhere near genuine just get a heavier rear sway bar and save up for the Bilsteins. Stock springs will be OK.
thanks for the suggestions guys - Ive got quoted 250 each for the swaybars - was thinking to do the rear first and the front later...
On a seperate note I just installed the Pioneer DVH-P4150UB Head Unit with DVD out to the factory Xanavi screen - Im pretty impressed with the picture (seems a good buy since it was under $400) just need to work out how to over-ride the screen turning off when driving!
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
