  • 5 weeks later...
Maybe I'll stand for parliament one day..."I drive myself to work" could be a platform ;)
The pricks just rely on scaring the mums and dads with taking a few bucks of child support off them and who cares about road safety and revenue. If someone actually made a platform of proper safety management and driver education it would be a shoe in but since they make it about other s**t then the elections are more and more about who is going to screw the health/school/welfare system less.
I'd like to see a proper referendum on attitudes toward road safety policy and see where that goes.......
business should make more noise as every dollar that speed cameras takes off people is a dollar less that they have to spend on luxuries that the pollies certainly do not do without.
Here's an angle. Older/cheaper cars are likely to have a less accurate speedo (I'm a mechanical Engineer and mechanic OK) and are more likely to be pinged in the 3kmh tolerance. Who owns the cheaper cars??? The less well to do!! Which sector of the community is paying the most in speeding revenue??? I bet the poor are because they cannot afford the legals or the expert engineering advice (I DO NOT pay speeding fines, It's a matter of knowledge and understanding). And the govt are just continuously bleeding the little guys dry and wondering why personal debt is spiralling out of control.
OK rant over, but this is a real hatred of mine.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
