JVC MP3 Headunit KD-LH2000
$500 firm - Its only a few months old and in IMMACULATE condition. An absolutely awesome little unit.
- Have everything that it originally came with: Box, Manuals, Installation Instructions, Remote, Surround, etc.
- Will happily ship interstate at buyer expense (which with prior experience will cost approx $30 registered post, including lots of bubble wrap and insurance).
- Will quite happily help someone install the unit in their own car if they want, its quite straight forward.
- Actual photos of the HU whilst it was installed in my car whilst I had the unit set to diplay in blue.
- Can take more photos if required.
- For those that want to see it really really close up, see here (340k):
Large Close Up Photo (Click Me!)
Quick feature overview (the useful and funky things about this HU):
- 50w x 4
- MP3 obviously
- Flip down face for CD loading
- Fully featured 3D dot matrix screen display (with animation)
- Random or user configurable screen colours (something like over 1000 different colour combinations, you can make this match the dash of your car for that fully integrated look)
- 3 pairs of gold plated RCA outs (front, rear, sub)
- Sub control (level and frequency control)
- Reason for selling: got something even better coming in.
RRP $749
Ref: http://www.bathurstlivewire.com/cncarsound.html
Full product details and specifications can be found here (unfortunately not on JVC's Australian website any more):
http://www.jvc.ca/en/consumer/product-deta...model=KD-LH2000
Product manual can be found here:
http://www.jvc.ca/en/consumer/downloadmanu...?f=49733ien.pdf
For a quick reply, drop me a PM or Email:
[email protected]
Located in Sydney.
Cheers,
Roman
https://www.sau.com.au/forums/topic/28276-fs-jvc-mp3-headunit-kd-lh2000/
I've got one of these in my car, bought it the day it was released in Oz :(
Can honestly say it's an excellent head unit, the ability to adjust the day and night colours to ANY hue and shade makes it a well worth buy, the fact it plays MP3's makes it even better.
User rating 10 out of 10 :(
Good luck with the sale!
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
