these turbos were on my rb26 gtst motor got rebuit and run in. went to mechanics to get boost and that adjusted and car blow a turbo manifold gasket mechanic or his apprentice changed that and left a rag in the inlet of the rear turbo motor was started and turbo begain to eat the rag im guessing rag was removed and car was started again was sitting on idle and started to blow heaps of thick white smoke blow turbo.
these are great for spare pair or someone to rebuild. i will get numbers if someones keen. car and parts are at a mates who has storage. i no had a/r 60 lol prob not much help
after $600 ono are worth like 2000 + new
car was making good power when i brought it for 10 min than spun bottom end hence rebuilt motor
car also for sale complete with standart 32 turbos. $11500
can be contacted on 0411672105
https://www.sau.com.au/forums/topic/282762-r32-nismo-gtr-turbos/
should be on a plate on the core between the in and ex housings
should be a series of numbers
such as 14411-RS581 which is the particular ones I am looking for :)
[edit]
a/r 60 is promising :(
Edited by Betz
Which is the good turbo in the pics and which is the stuffed one ? Need a few more pics as one intake wheel looks bad - si that the one with the rag chew - whats the other one like.Post up a pic of the tag with numbers and ID on please.
offers please need to sell
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
