Rb26 Plenum And Itb On Rb20
boostn32
 Share
  • Replies 44
Welcome mate. Nice fabrication work though. If you dont use it im sure someone with an RB25DE head on their RB30 would use it. They are aparently the same intake port size.
Have a look at this thread, It's not completely compatible with what you are asking but they used a GTR plenum welded onto the RB20 runners, standard RB20 bottom end, standard cams with shimmed valve springs, big turbo and lots of boost. Was just done for shits and giggles to see how much a standard RB20 can take before they blow. they made 370rwkw and never killed it. The boost flat line is because that's the max' of the MAP sensor.
http://www.skylinesaustralia.com/forums/Tu...-M-t214053.html
Edited by D_Stirls
That's what I used as an example when building my manifold.
  • 4 weeks later...
Well its about a month later and thought i would post up what has happened, i didnt end up getting to the dyno and parts didnt turn up so it all
just seemed to fall in a heap. i have the manifold nearly all done just a few small things to do, then i can move onto the rest of the build.
i would guess there is around 20 hours in porting this manifold and the runners all end up perfect. no lumps or bumps and a very smooth flow
through the manifold joins. there wont be much progress for a while now untill i get back from japan in late october. and before i can get this one finished
there is a new build in the pipe line for a 1000hp 4cyl nissan engine to go into a 1200 ute. what 4cylinder you ask? time will tell and its not what you think!
Has to be a CA, :)
 Share
