  • Replies 44
Have a look at this thread, It's not completely compatible with what you are asking but they used a GTR plenum welded onto the RB20 runners, standard RB20 bottom end, standard cams with shimmed valve springs, big turbo and lots of boost. Was just done for shits and giggles to see how much a standard RB20 can take before they blow. they made 370rwkw and never killed it. The boost flat line is because that's the max' of the MAP sensor.
http://www.skylinesaustralia.com/forums/Tu...-M-t214053.html
Edited by D_Stirls
That's what I used as an example when building my manifold.
  • 4 weeks later...
Well its about a month later and thought i would post up what has happened, i didnt end up getting to the dyno and parts didnt turn up so it all
just seemed to fall in a heap. i have the manifold nearly all done just a few small things to do, then i can move onto the rest of the build.
i would guess there is around 20 hours in porting this manifold and the runners all end up perfect. no lumps or bumps and a very smooth flow
through the manifold joins. there wont be much progress for a while now untill i get back from japan in late october. and before i can get this one finished
there is a new build in the pipe line for a 1000hp 4cyl nissan engine to go into a 1200 ute. what 4cylinder you ask? time will tell and its not what you think!
Has to be a CA, :)
    • Jamie does know his stuff , you might just want to give them a call and ask - here is their FB page  -  https://www.facebook.com/profile.php/?id=100063506985512 - you will find the number to call them on.
    • Do you think the guys in Penrith are install the E85 Kit?
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
