Hey, hey,
Its DECA this Sat :(
So I guess its time to put up the DECA Cruise thread for all those who want to meet on Sat morning for the drive up to Shep.
When: Sat 15th
Where: Wallan outbound BP on the Hume.
Arrival: 5:45am
Departing: 6:15am, can wait to 6:30am max if someone is running a little late
CBs are welcome Ch14, (i dont have 1, but if someone has one spare let me know)
Map of Meet Spot
See you there!!!!!
There is Maccas, KFC, Subway, whatever floats your boat realy...
I'll probably be getting my breakfast at Shep Maccas, too bad their service sux, waiting 15mins for food :P
Hey Guyz will be there by 6:15 am.. Just to confirm the address is it this-> 1052 Hume Fwy, Craigieburn VIC 3064...
Because ill be putting it in my GPS, as i have no idea wer ill be going. And could someone pm me their no also so incase i get lost i can contact someone..
Thanks!!
Thanks!!
Nah sorry, that is the location of Donnybrooks Shell, the location of the BP is the coordinates,
I used the link out of my old Deca cruise thread where i showed the BP location compared to Donnybrooks Shell
Google maps sucks and did not give me an address.
You could use the GPS to get to Donnybrooks Shell and then just continue on the Hume for around 10 more mins, until you see a BP servo
Its realy impossible to get lost once you are on the Hume :P
Thanks!!
mate you wont get lost.
get on the hume, you'll go pass the shell on the left, then the caltex on the right, then hit the 110km zone and the BP is 10-15min in from there.
its signed at 5km and 1km out. cant miss the signs they are huge.
Good work guys...
Just make sure you are all at the DECA facilities at 8:00am ready to go..
This means get yourself some breakfast and have your car fueled up before you get there...
Then we can get through scrutineering and drivers breifing quickly and get under way to make sure we get maximum track time!!
See you all there!
Just took a look at the map and well it looks pretty easy so ill just put in the donnybrooks shell address and then ill keep continuing on till i see a BP..
Would be helpful if i can get someones number, if they dont mind!!
oops didn't realise i didn't put my number in the 1st post..
if anyone got any questions, my number is: zero four three zero one three one zero two zero
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
