hey guys i am basiclly a first time writer but long time onliner if you get my flow.....
im in the market for a r32gtr and tonite i went and had a look at one, now ive been searching for a while and the one that i took a look at is fairly standard and looks pritty legite.......
what do u guys think????? "i took my skyline manual with me and it pritty well checks off every thing in the list?
http://www.carsales.com.au/all-cars/privat...id=1223C82ACD25
one thing, he claimed it makes 239 kws at the rears with the 4wd disingaged cause of the fact he was on a two wheel dyno but is still runing standard boost wat do u think modds are as followed on the link
also the frount mount didnt look standard
cheers in advance
giuseppe
Edited by r32gtr92
https://www.sau.com.au/forums/topic/282789-my-first-skyline/
  mxfly said:
I think he's pulling himself with 238kw with very little power mods. Well, unless he can prove it.
Yeah +1.
Ask him for a Dyno sheet print out.
Seller says:
"Engine is mechanically sound and exterior is in great condition. Very clean and neat car that gets driven a maximum of twice a week.
Extras:
Stainless steel 3" Greddy catback exhaust,
Exceedy heavy duty clutch,
Pod filters,
Alpine stereo speakers
7" Motorised LCD DVD/VCD/TV Player (USB and SD card compatible),
Remapped ECU
Turbo Timer.
All resonable offers will be considered"
Car looks pretty stock to me... Cat back exhaust, twin pod filters and a Remapped ECU = 239 Rear Wheel kW's..?
Don't think so.
Ask him what has he done to the ECU, stock or aftermarket?
Remapping an ECU means fine tuning the the Unit to get better performance out of your car by altering the Air/Fuel Ratios, settings...
In doing so to try and increase power and torque and making the car more responsive down low, mid range or top end and try to cancel out any flat spots in the power and torque curves.
After doing so I still can't see how he got 239 rw kW's unless having Dyno sheet to prove.
  import92 said:
cheers 00skyline00 ,
thats what i thought took it for a test drive and it felt pritty quick compared to stockers that ive been in but like you said i dont think its possible either,
great responsiveness i must say?
gonna call for a dyno sheet for proof.
  r32gtr92 said:
wopps didnt relise i was loged in to my lost acount that i didnt think was there any more,
as above
all comments are welcome>?
Yeah no worries!
But still take another look into the car, if it runs well and a tad quicker then standard, in a good condition...
Do a bit more research, ask a few more questions and even take you mechanic down with you next time to see the car.
The seller is negotiable on price so take a stab at it... He wants $18,499, then see if he will take anything in the $16K range.
If not then you both meet each other half way on the price, say $17,500 or whatever...
If he won't lower the price, meaning he still thinks his car has some good mods and can make 239kW's. (Trying to get some money back on the "Mods" he has done")
If he is willing to lower it then you know it's pretty much stock...
My point of view anyway and this is all in speculation, cuz I am not standing in front of the car and just judging from the Carsales add.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
