Hey guys,
im new here as you can probably tell, but im planning on buying a skyline next week or the week after (If all goes to plan).
The car i am lookin at is very nice, but theres one problem, its an auto, i prefer to drive manuals as i feel i have alot more control over the car and its speed (ie. changing into a certain gear for certain speeds, etc etc u know how it is)
i have no problem driving the car as auto - because im jus so amped that i have the car i wont care ... but when and if the time comes, how much would it roughly be to drop a manual gear box in it?
or.... how much would it be just for a good quality gearbox and parts needed etc ? (im soon to be an apprentice i hope and can probably put the new gearbox in myself with a bit of help from someone experienced.)
thanks for your time, sorry if i rambled on a bit.
https://www.sau.com.au/forums/topic/28279-r33-auto-to-manual-conversion/
Most people will say just buy a manual. i gotta agree but hey you cant always get what you want.
Hardest part is finding an r33 box, expect a minimum of 1.5k for one. Next is clutch at least 500 bux then pedal box master slave cylinders, so even without labour your looking at 2-2.5k
Have a good one
Mirkz,
meggala's site has a run down of what's involved.
do a search for meggala - he's on the forums and there's a link in his sig, or alternatively, just google it.
I went through this when I was thinking about a soarer - cause the cost of conversion seems to sit in the order of three grand but the cost of buying a manual in the same condition can be up to 5k.....
anyway I ended up buying a manual line because I wanted a drivers car not a weighty battleship..
the cach is that whilst you can buy an auto and convert it, most people get their auto cars here and end up tossing up between a dog box and a new turbo...or a computer and intercooler package..
basically you can make an auto go a lot faster for the same price as a manual - but the catchn is it's still an auto.
either way you end up paying......and so most people just buy the manual to start with and save the hassle...
..but each to their own, and if you're in a position to be able to do most of the work yourself, you may find that it's most cost effective to do the conversion yourself...give meggala's site a rinse and suss out what's involved.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
