hey guys, just after some quick help, im up for spending some money on my rb25 in an r34 skyline gtt. i have done the splitfires, exhaust, boost controller, and now im stuck for what to do next.
if anyone can give me a general guide/ an order of next mods, that would be wonderfull.
https://www.sau.com.au/forums/topic/282803-next/
rip it out.
chuck in a r33 rb25det and forge it.
neo's can be difficult to work on.
but if u only want 350ish hp, grab a power fc, clutch, injectors, gt35r, wastegate, FMIC, new dump pipe/hi mount manifold, tune, plazmaman plenum and your laughing.
thats pretty mild tho.
forge a r33 rb engine ;):(
Edited by r33cruiser
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761061
rip it out.
forge a r33 rb engine :):D
Oh wow, I didn't realise that the suggestions had to be reasonable, or within a budget
In that case, what you should do, is rip the engine out and mid/rear mount a Rolls-Royce/Snecma Olympus 593 jet engine into the car.
As we all know, neo engines can be quite tricky to work on, and aftermarket parts aren't always that easy to find, i thought it would be far easier to bypass all that and just slot a Concorde engine into your skyline.
Some minor body modfications may also have to be done due to the dimensions of the engine being 4 metres long and 1.2 metres in diameter.
It's all worth it though as you will have 31,500 lbs of thurst at your disposal. That's without engaging afterburners, but we all know afterburners are for fags...
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761397
:D I rate this post lol
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761468
Yeah you could do mad skids with that....
But seriously.
KKR turbo, new dump.
PFC
Pod and cold air induction.
FMIC.
fuel pump
fuel reg
tune it!!!
Don't even worry about injectors, you don't them to get 350bhp, just get them cleaned.
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761642
Will it break traction in 2nd?
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761877
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
    • If the original NA ECU has a separate TCU then you are going to need to reroute wires that used to run between the trans and the TCU to the appropriate (1 to 1 equivalent) pins on the ECU. Other than that, it should work. Look up posts by @Kinkstaah on the subject.
    • So the stagea was a series 2 neo det with tiptronic auto. (I have the transmission aswell) and has integrated tcu in the ecu. I'm hoping to use the entire stagea ecu, engine and auto harness.
