hey guys, just after some quick help, im up for spending some money on my rb25 in an r34 skyline gtt. i have done the splitfires, exhaust, boost controller, and now im stuck for what to do next.
if anyone can give me a general guide/ an order of next mods, that would be wonderfull.
https://www.sau.com.au/forums/topic/282803-next/
rip it out.
chuck in a r33 rb25det and forge it.
neo's can be difficult to work on.
but if u only want 350ish hp, grab a power fc, clutch, injectors, gt35r, wastegate, FMIC, new dump pipe/hi mount manifold, tune, plazmaman plenum and your laughing.
thats pretty mild tho.
forge a r33 rb engine ;):(
Edited by r33cruiser
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761061
rip it out.
forge a r33 rb engine :):D
Oh wow, I didn't realise that the suggestions had to be reasonable, or within a budget
In that case, what you should do, is rip the engine out and mid/rear mount a Rolls-Royce/Snecma Olympus 593 jet engine into the car.
As we all know, neo engines can be quite tricky to work on, and aftermarket parts aren't always that easy to find, i thought it would be far easier to bypass all that and just slot a Concorde engine into your skyline.
Some minor body modfications may also have to be done due to the dimensions of the engine being 4 metres long and 1.2 metres in diameter.
It's all worth it though as you will have 31,500 lbs of thurst at your disposal. That's without engaging afterburners, but we all know afterburners are for fags...
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761397
:D I rate this post lol
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761468
Yeah you could do mad skids with that....
But seriously.
KKR turbo, new dump.
PFC
Pod and cold air induction.
FMIC.
fuel pump
fuel reg
tune it!!!
Don't even worry about injectors, you don't them to get 350bhp, just get them cleaned.
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761642
Will it break traction in 2nd?
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761877
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
