hey guys, just after some quick help, im up for spending some money on my rb25 in an r34 skyline gtt. i have done the splitfires, exhaust, boost controller, and now im stuck for what to do next.
if anyone can give me a general guide/ an order of next mods, that would be wonderfull.
https://www.sau.com.au/forums/topic/282803-next/
rip it out.
chuck in a r33 rb25det and forge it.
neo's can be difficult to work on.
but if u only want 350ish hp, grab a power fc, clutch, injectors, gt35r, wastegate, FMIC, new dump pipe/hi mount manifold, tune, plazmaman plenum and your laughing.
thats pretty mild tho.
forge a r33 rb engine ;):(
Edited by r33cruiser
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761061
  r33cruiser said:
rip it out.
forge a r33 rb engine :):D
Oh wow, I didn't realise that the suggestions had to be reasonable, or within a budget
In that case, what you should do, is rip the engine out and mid/rear mount a Rolls-Royce/Snecma Olympus 593 jet engine into the car.
As we all know, neo engines can be quite tricky to work on, and aftermarket parts aren't always that easy to find, i thought it would be far easier to bypass all that and just slot a Concorde engine into your skyline.
Some minor body modfications may also have to be done due to the dimensions of the engine being 4 metres long and 1.2 metres in diameter.
It's all worth it though as you will have 31,500 lbs of thurst at your disposal. That's without engaging afterburners, but we all know afterburners are for fags...
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761397
:D I rate this post lol
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761468
Yeah you could do mad skids with that....
But seriously.
KKR turbo, new dump.
PFC
Pod and cold air induction.
FMIC.
fuel pump
fuel reg
tune it!!!
Don't even worry about injectors, you don't them to get 350bhp, just get them cleaned.
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761642
Will it break traction in 2nd?
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761877
