hey guys, just after some quick help, im up for spending some money on my rb25 in an r34 skyline gtt. i have done the splitfires, exhaust, boost controller, and now im stuck for what to do next.
if anyone can give me a general guide/ an order of next mods, that would be wonderfull.
https://www.sau.com.au/forums/topic/282803-next/
rip it out.
chuck in a r33 rb25det and forge it.
neo's can be difficult to work on.
but if u only want 350ish hp, grab a power fc, clutch, injectors, gt35r, wastegate, FMIC, new dump pipe/hi mount manifold, tune, plazmaman plenum and your laughing.
thats pretty mild tho.
forge a r33 rb engine ;):(
Edited by r33cruiser
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761061
rip it out.
forge a r33 rb engine :):D
Oh wow, I didn't realise that the suggestions had to be reasonable, or within a budget
In that case, what you should do, is rip the engine out and mid/rear mount a Rolls-Royce/Snecma Olympus 593 jet engine into the car.
As we all know, neo engines can be quite tricky to work on, and aftermarket parts aren't always that easy to find, i thought it would be far easier to bypass all that and just slot a Concorde engine into your skyline.
Some minor body modfications may also have to be done due to the dimensions of the engine being 4 metres long and 1.2 metres in diameter.
It's all worth it though as you will have 31,500 lbs of thurst at your disposal. That's without engaging afterburners, but we all know afterburners are for fags...
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761397
:D I rate this post lol
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761468
Yeah you could do mad skids with that....
But seriously.
KKR turbo, new dump.
PFC
Pod and cold air induction.
FMIC.
fuel pump
fuel reg
tune it!!!
Don't even worry about injectors, you don't them to get 350bhp, just get them cleaned.
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761642
Will it break traction in 2nd?
https://www.sau.com.au/forums/topic/282803-next/#findComment-4761877
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
