a puggy backed ecu, the best kind
nothing like a small ugly dog backing up your ecu
Baahhhaaaa
Hey Josh, if your making 185-200kw atw your next mod will have to be a clutch. Mine gave way at the power your making now so prob best to get a new one before the current one shits itself :D Oh yeah and when buying a clutch try and plan ahead and get one that will suit the sorta power your aiming for e.g. 300kw atw is a good figure for the neo's.
Ide also recommend getting rid of the piggy back plug in shit and get a new ecu (nistune, vi-pec, apexi pwer fc, wofl) Depending on personal preference and what your tuner can do.
Edited by Danski
https://www.sau.com.au/forums/topic/282803-next/page/2/#findComment-4775515
ok *piggy backed haha i read my post just then and was like......frick....... haha.
yeah, WELL you see the thing about the clutch is i have an auto at this point. deciding over a shift kit or a manual conversion. well i want to get a new ECU, probebly impul or haltech plat. well see how we go. nistune? i keep hearing this, is it a garage or what is it?
https://www.sau.com.au/forums/topic/282803-next/page/2/#findComment-4782450
Nistune ECU.
I dont know anything about them but EFI performance are an authorized dealer so if you got any questions you could give Rick a call on 07 3801 8075.
Edited by Danski
https://www.sau.com.au/forums/topic/282803-next/page/2/#findComment-4782477
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
