Sold my car so this stuff can go too
Fiberglass wide guards. New never fitted. Ready for paint/install-- $150
White face dash cluster with 79,000 ks on it. Looks like this buts its a full cluster and kit-- $100
turbo smart Vee port blow off valve. --$150
white line sub frame locking kit (drift pineapples)(all 8 bushes) Stop that dreaded axle tramping. what are these worth. Not sure --$80 ?
full set of r32 stockies painted black with average tyres yokohama's. 2 rwc, 2 maybe road worthy-- $250
2x stockies (silver) with shagged continentals- $50
https://www.sau.com.au/forums/topic/282818-r32-parts-sale-wheelsbov/
The white face dials I am interested in but the photo looks like it's for a GTR not a GTS-T as it has the front torque split guage. Can you confirm if this is the actual one you have or whether yours is for a GTS-T please?
Thank you.
Cluster is from GTS-T
Photo was just to get an idea. Ill get real pics soon
Lights up Blue
Gaurds not sure wat brand. Sorry
White line not in packet so i have no idea.
Sorry hope this helps.
I'll take the cluster please. How much postage to 5255?
Also, do you have the dash surround and is it a manual surround (without the automatic strip)? If so, how much do you want for that included? Mine's had a hole cut into it for a boost gauge which looks awful.
Cheers,
Sparky
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
    • Not required but appreciated. Super Coppermix Twin even the non-competition model feels like the pedal is noticeably heavier than stock which was pretty well judged IMO. I'll be swapping in the Nismo operating cylinder soon to see how that feels.  Personally I haven't felt anything that justifies replacing the damping loop, at least compared to more modern stuff where the clutch delay valve is actually quite noticeable.
