  • Replies 44
hey mate if you still have this stuff? pm me a price on,
rear calipers,
rear backing plates,
rotors and pads,
and handbrake cables,
cheers,mike
Hey guys i am currently wrecking an R33 S2 in silver. I have pretty much all the parts from the car, as can be seen from the photos there are many parts which were destroyed but if you see something you like let me know and i can get more pics and let you know a price.
- Bare Shell with good Compliance not on the Register as Written Off $1000
- Twin exhaust pipe complete $400
- Boot lid in Perfect nick painted silver with Genuine GTR Wing $450
- Drivers Side switch panel in good condition believe it or not $120
- Full Airbag setup including drivers, passenger, crash pad, clock spring, control module $1000
- Series 2 Boot Trim complete and in great condition $140
- Full Lock set including ignition, door locks, boot lock and key $150
- Front brake setup with calipers, pads (pretty sure EBC green stuff) rotors etc $350
- Engine Package including turbo, wiring, loom, ecu $2200
- Auto Gearbox $200
- Passenger side mspec skirt slight damage $75
Chasing coilovers, so these sold ? Cheers
- Turbo Auto diff (good ratio) $400
- Rear brake setup $250
- Tein HA height and dampner adjustable coilovers $750 for full set
If you see any other parts you think you may want let me know and i can arrange photos for you no probs, Alos have a few other cars im wrecking so let me know if there is anything specific you need as i might be able to get hold if it for you.
All prices are negotiable and parts are located in Campbellfield, Victoria
Cheers Luke
Thanks for reply on coilovers. What your evaluation on these ? ok, their second hand, which i appreciate
and dont expect a new product but were they knock free, leak free ? Having driven for a while, would have
a pretty fair idea on their condition ? Cheers
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
