Heys guys im just looking at mayb doing a small turbo upgrade, i want something that bolts straight on to standard flange etc etc somethings thats suitable and good but in the low price range to?? or even just highflow standard turbo?? can any 1 give me some options, suggetions
oh and its and rb25
thanks
https://www.sau.com.au/forums/topic/282837-upgrade-turbo/
HKS GT2535 (350HP) GT2540 (400HP)
HKS GT-RS (400HP)
HKS GT2835 PRO S (450HP)
All the above will bolt onto stock manifold, and use stock dump pipe (apart from the 2835 but if you buy the kit it will come with the dump pipe).
Will make good power with a aftermarket fuel pump, injectors, afm and ecu
Edited by Kaido_RR
https://www.sau.com.au/forums/topic/282837-upgrade-turbo/#findComment-4760653
ZOMG FLAMES OF THREAD DOOMMMMMM !!!!eleven
USE THE SEARCH FUNCTION...... oh wait it Broken and comes up with some french error crap. WTF
Board Message
Sorry, an error occurred. If you are unsure on how to use a feature, or don't know why you got this error message, try looking through the help files for more information.
The error returned was:
Erreur Sphinx : searchd error: unknown local index 'ipb_search_topics' in search request
Merci de contacter un Administrateur !
Anyway a hiflo is the only thing that will bolt straight up. A HKS 2530 or 2535, GTRS, 2835 etc will bolt up to the manifold, but oil lines and dump will have to be replaced with different ones. But any garret 2871 would be sweet for 350RWHP.
Good luck
https://www.sau.com.au/forums/topic/282837-upgrade-turbo/#findComment-4760669
While HKS are awesome they are a lot more expensive, then again the kit comes with everything you need (oil/water lines, gaskets, bolts, etc). I hear HKS are pretty much Garret turbo's re-engineered for more response/power.
Tell us how much money you want to spend, and what mods you already have.
Edited by SKYRYAN
https://www.sau.com.au/forums/topic/282837-upgrade-turbo/#findComment-4760999
kk atm i have 270 rwhp i have zorst, cooler, airfitler, greddy emanage but im about to change it for vipec ummm thats about it just all the other usal stuf like highflow cat etc etc, im not to sure weather i need to change injectors, but i need to change coilpacks and fuel pump? i want around 350hp and spend around the 3k mark if possible.
thanks guys
https://www.sau.com.au/forums/topic/282837-upgrade-turbo/#findComment-4762025
Search the forced induction thread
Hypergear seems to have a good results for huflowing and for just under $1000 including oil/water lines its pretty good bang for buck
i think the KKR turbos from otomoto needs a new dump pipe?
https://www.sau.com.au/forums/topic/282837-upgrade-turbo/#findComment-4762066
if you want bolt on go the HKS range they are bolt on provide good response but they can be dear, how ever they always pop up on yahoo auction, HKS2535, GT-RS is good turbo for 300-350 hp range and response is like nearly same as the stock turbo :)
https://www.sau.com.au/forums/topic/282837-upgrade-turbo/#findComment-4762136
Good luck
HKS GT2530,2535 and GTS-RS Use the stock flange for the dump pipe so you can use your stock one or an aftermarket one if you already have one. Also from my experience you can also use the stock lines (water and oil) on the 25** series turbo.
GT-RS comes in a kit with everything you need as does the 2835 PRO S
Jap brand turbos are a rip off, go with garett.
How are they are rip off?
https://www.sau.com.au/forums/topic/282837-upgrade-turbo/#findComment-4762264
thanks guys
Firstly i think your 270rwhp figure is inaccurate. Could be a happy dyno but you wont have that power with those mods.
I am going to assume you mean you want 350rwhp
3k will not cut it
you will probably need a gt3076r or gt3071r may scrape that power. $1900
injectors & z32 afm $1200
custom dump and cooler piping $500
oil and water lines $300
New computer $1650 vipec
bosch 044 fuel pump $250
Tune $500-800
$6300 - 6600
Thats without labour as well. Your dreaming if you think 3k will get you 350rwhp
And yes you can use garrett turbos on stock manifold. Just use spacer or a few gaskets.
I think you either gotta bust out some serious doe for an upgrade or be happy with mild mods.
Then keep in mind you will gain lag with the bigger turbos.
If you went the hks route it would probably cost another $700 ontop of that
https://www.sau.com.au/forums/topic/282837-upgrade-turbo/#findComment-4763473
How aren't they a rip off? GT-RS are around $3500 for the kit, I would rather buy a GT3076 kit which is cheaper and has WAY more potential
When the exchange rate was really poor around the 60 mark, i bought in a GT-RS kit which cost $3000 all up
Now that the exchange rate is back up you will be looking around the $2500 BRAND NEW.
which is very good bang for bucks! complete kit inc all lines and gaskets, for a between 300 - 400rwhp doesn't seem like a rip off.
https://www.sau.com.au/forums/topic/282837-upgrade-turbo/#findComment-4763483
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
