im thinking of relocating my number plate to the RHS, just wondering how u guys mounted it.
i dont really wanna drill into my bumper in case i wanna move it back, but is that how every1 else is doin it?
would double-sided tape hold it? im just worried at high speeds if its gonna hold (on the track of course :P )
https://www.sau.com.au/forums/topic/282843-relocating-front-number-plate/
would double-sided tape hold it? im just worried at high speeds if its gonna hold (on the track of course :D )
i hope you mean passenger side ?
drivers side is ILLEGAL due to camera not being able to read it so cops will rape you if you hae it there
I had mine on the drivers side
I always carried around a speeding fine in my glove box that clearly showed the camera seeing my plate
never got in trouble but the guys at the pits made me move it to the middle before they would pass it
ill probly end up using double sided tape n see how that goes :)
as for it being illegal on the drivers side thats probably true, but a stupid law as ive driven past speed cameras on both the left and right hand side of the road.
cheers fellas
i dont think its illegal as such i was told ( by an inspector) that as long as the plate is straight and can be read from anywhere in front of the car its fine but the fuzz will still use it as an excuse to pull you over
ive put mine on the drivers side with a small bracket fixed into the underside of the bumper
double sided tape did the trick, excuse the crappy fone pic.
i recon the front end looks alot better now :D
of yeh i ended up using my apexi safc stand to hold on 1 side of the plate lol, came in handy
Edited by jimmys-33T
I had it on the drivers side...was there for 2 yrs.... multiple rbts later... then one officer mentioned to move it... i moved it then and there... he then complained the holes were it once was wasnt correct and I'd need a new front bumper... but as it is now the plate is on the passenger side and they have left me be since. just a thought.
All recent Alfa Romeos have their front plates on the left side. So, if some cop tells you that you cannot have it to one side, he/she is talking through the wrong part of his/her anatomy. I am sure there is some other make around that has a side-mounted front plate, which is on the right, but I cannot remember which one! The ADRs only require that the plate is parallel to your front axle (or some other definition of straight), i.e. it cannot be angled to one side, and vertical, i.e. it cannot be sloped back.
I have left mine on the middle, but the workshop moved it up, so only a third of it protrudes into the intake area. Some shims help overcome the indentation in the bar, so it can sit flat. A slight bend back at the bottom and top would help airflow.
Cheers.
I dont think rhs should be any problem at all,eg: a NISSAN nomad van is mounted stock on rhs. http://tbn0.google.com/images?q=tbn:6we0IF...33945-thumb.jpg this is the stock mounting spot..............so im guessing whats good for the goose is good for the gander...
Edited by r31gtsxjspec
    • Oh, I forgot too, all the multimedia stuff captured and sold through things like people playing Pokemon Go. Pokemon Go specifically, can actually be traced all the way back to a CIA investment company too. So yep, they're watching everything. Not to mention the new stuff where they've worked out how to use WiFi signals to be able to map occupants inside of a building. That one would be something that I see being more used in public/government buildings, as you need to understand the signals when the room has no one in it first. It's not as easy as Hollywood would like you to think it is.
    • Followed ☺️ Assuming those are NEO rods, then at least 400kW all day.
    • Lets keep this going , Spotted this very stock V35 in Penrith and also saw a nice R32 FLY past me on Castlereagh rd , sounded really good.
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
    • I'm not a fan of high humidity, it's one reason I don't mind being further inland out Ipswich, except the last 3 odd years, the drought broke, and it won't stop raining, which is making the humidity nearly unbearable when the rains are in during summer! For me, my body hates the cold, once the cold sets into my body, I'm totally screwed. I end up with severe muscle spasm in my back/shoulder muscles, and it feels like someone is trying to tear the muscles out. I have no issues with it getting stupid hot, so long as the humidity goes away. So the last 3 years as above, have been woeful! Ha ha. However, June 1st, and I'm only just converting from shorts and a tee, to long pants and a t shirt. And that's mainly as it's a bit wet and miserable and I wanted to work on a car.
