not sure if there is a thread anywhere on this, but the search facility doesn't seem to be working.
How big a job is it to remove the transfer case to inspect/replace the clutch pack?
I am told thats whats gone on mine...
many thanks
bump..
https://www.sau.com.au/forums/topic/282851-transfer-case/#findComment-4765039
They are expensive to replace from what I've heard, are you 100% sure its the clutch pack? Did someone take it apart and have a look or is it a guess?
I broke an actual shaft inside my transfer case, I bought a second hand one and kept the parts that were intact :P
https://www.sau.com.au/forums/topic/282851-transfer-case/#findComment-4766684
I broke an actual shaft inside my transfer case, I bought a second hand one and kept the parts that were intact :(
have asked a few people and the generally concensus is that i's the clutch pack..
under hard acceleration this kinda judder jumpy feeling came from the passenger side floor with a nasty crunchy noise.
Now I just have rear wheel drive ( if all four wheels are lifted and the cars in gear..the fronts do spin but they can be stopped with your foot.) The pump seems to be priming ok but I'm not sure how to check the pressure..
https://www.sau.com.au/forums/topic/282851-transfer-case/#findComment-4769652
Interesting, my car effectively stopped moving, both rear and front when the shaft broke, I could release the clutch and rev to 3K RPM, wait 3 seconds and then the car would start moving.
In fact it would not stall with clutch out.
Anyway, Racepace and Award diff and gearbox are known to rebuild them, but neither are cheap, from memory $800-1000, I went second hand for $400. I saw one around $200 second hand at the time but unknown condition...
https://www.sau.com.au/forums/topic/282851-transfer-case/#findComment-4769689
I am now in a similar situation.. transfer case clutch packs gone. Hardly surprising considering the age, condition and usage. Mine just spins off same as a motorbike clutch slipping when it is stuffed, gauge moves but rears spin. Checked that pump works, bled system, and then dropped it in to a local specialist workshop for confirmation. I don't have a gauge assembly to test the pressure.
Rebuild and labour I was quoted just on $2.5k. I have picked up a secondhand unit which I will be inspecting and probably get the same workshop to fit. Cost will be closer to 1k, if everything is good, big if though.. They picked a bad intake manifold leak as well so yet more repairs that I have to do..
https://www.sau.com.au/forums/topic/282851-transfer-case/#findComment-4770151
Perth is a very small city.. That quote was including the labour for removal and refit of the gearbox as well as the work on the gearbox itself, if you aren't adding that into your consideration.
All up I considered it a fair price.
https://www.sau.com.au/forums/topic/282851-transfer-case/#findComment-4770609
Who quoted the 2.5K? My previous calls were a lot lower on price for a rebuild, I think it was $1400 or so with the upgraded clutch packs to handle higher power levels...
are ere any online traders who have uprated clutch packs??
https://www.sau.com.au/forums/topic/282851-transfer-case/#findComment-4770616
Ok sure, as long as your happy with the price.
Just FYI, here in Melbourne the $400 second hand included the labor to remove/fit the second hand transfer case. Rebuilds obviously cost more, good luck.
https://www.sau.com.au/forums/topic/282851-transfer-case/#findComment-4772751
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
