Hey guys,
I will get pics up asap but for now these are the details:
1994 Subaru Liberty RS (the genuine factory turbo wagon)
It is white body in immaculate condition not a flaw to it, and it has the following:
Lowered with new springs and shocks
5 spoke light weight rims (will get brand for you)
Dark tint
Full 2.5" exhaust with a cannon (i dont like the cannon so it will soon be replaced with a muffler with twin 2" tips)
Boost guage
Full sound system - Sony HU, Sony speakers and an Alpine/JBL 10" Sub and amp pack (amp under pass seat for easy disconnection of sub to pull it out)
Momo Steering wheel - black leather
5 speed manual
body has 260xxxkm on it however the drivetrain has been replaced with a 90xxxkm example from a 02 WRX
Before i put the engine in i replaced all the seals, belts and i replaced the lifters with fresh ones as these can get worn easily on subaru engines.
I have only ever run this engine with Non Synthetic Multigrade Oil 20w-40 and it has never missed a beat, i service all the fluids and filters every 4000km, i have just completed a service last week.
Has a turbo timer installed
White leather trim on Pillars
I have a dual stage boost controller but have never fitted it
Water to air top mount intercooler
The interior is immaculate, as is the exterior and this engine had been babied - have not even fitted the dual stage!!!
For any details PM me or send me a text on 0406457746
cheers,
Tim
https://www.sau.com.au/forums/topic/282862-subaru-liberty-rs-wagon/
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
