**autosports** Oran Park "grand Prix" Circuit, Thursday 17th September.
YES... THE GRAND PRIX CIRCUIT!!!
We are pretty stoked to be able to bring this date to you guys. Those that have driven this track will agree that it is without question the best permanent race track in the country
Those in the know also know that this track will 100% be closed at the end of this year and this could seriously be one of the last chances you will ever get to drive this circuit.
* $250 per driver
* Includes qualified driver trainers
* Official timing
* strictly 4 groups of 15 cars running 15 minute session
There is really only five weeks till these event and we dont want to wait till the last minute to get numbers sorted. I also don't think that it will take too long to book this event out given that dates on the GP circuit are so hard to access.
So if you want to experience driving this amazing and rewarding Grand Prix circuit... register for this event now and don't miss out!
TO REGISTER... CLICK HERE > http://autosports.tixi.com.au/oranpark
Link to thread for this event on Autosports forums for additional information is > http://forums.autosports.com.au/showthread.php?t=2192
Hey Peddler,
Long time no see. I registered for this great day. I loved SAU GP and I will like a repeat. I hope I reserved my spot via this TIXI reservation but, the $250.00 ticket costed me $264.30. So people if you register expect a little bit more!
Cheers,
Eug.
Brad's 32?
Yep yep, the one and only.
Going to try and put a passenger seat in it.
Hopefully it will last the whole day. It doesn't have a great track record with Oran Park.
  • 3 weeks later...
Here is some in car footage from my run during session 2. I've still got a bit to learn about putting the power down smoothly and trail braking more into several of the corners.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
