**autosports** Oran Park "grand Prix" Circuit, Thursday 17th September.
YES... THE GRAND PRIX CIRCUIT!!!
We are pretty stoked to be able to bring this date to you guys. Those that have driven this track will agree that it is without question the best permanent race track in the country
Those in the know also know that this track will 100% be closed at the end of this year and this could seriously be one of the last chances you will ever get to drive this circuit.
* $250 per driver
* Includes qualified driver trainers
* Official timing
* strictly 4 groups of 15 cars running 15 minute session
There is really only five weeks till these event and we dont want to wait till the last minute to get numbers sorted. I also don't think that it will take too long to book this event out given that dates on the GP circuit are so hard to access.
So if you want to experience driving this amazing and rewarding Grand Prix circuit... register for this event now and don't miss out!
TO REGISTER... CLICK HERE > http://autosports.tixi.com.au/oranpark
Link to thread for this event on Autosports forums for additional information is > http://forums.autosports.com.au/showthread.php?t=2192
Hey Peddler,
Long time no see. I registered for this great day. I loved SAU GP and I will like a repeat. I hope I reserved my spot via this TIXI reservation but, the $250.00 ticket costed me $264.30. So people if you register expect a little bit more!
Cheers,
Eug.
Brad's 32?
Yep yep, the one and only.
Going to try and put a passenger seat in it.
Hopefully it will last the whole day. It doesn't have a great track record with Oran Park.
  • 3 weeks later...
Here is some in car footage from my run during session 2. I've still got a bit to learn about putting the power down smoothly and trail braking more into several of the corners.
    • As in they quoted one price, you mentioned the exhaust, and they promptly added $200 on top? Interesting.
    • Note that I'm not suggesting this is a great idea. Just saying that it is something that could be done to achieve a better outcome than the more shit ideas will provide.
    • I'd try removing it, connecting hoses and see if that helps. Depending on specs, it could actually be restricting the flow(it also might be helping).
    • Yes, that's a hybrid BOV. The adjustable spring load ones are about making teh pressure build up higher before venting, so you get a more agressive whoosh. That is not what I meant or what you want. By "restricting", I don't mean "keep it closed until the pressure is higher, then open it fully". I mean "open it as soon as it is required, but only have a small port area, so that the flow rate out of it is slowed down". The pressure will rise to be higher than a bigger ported BOV would provide, but it would do while it is venting. The idea is to slow down the rate at which the replacement eair is flowing past the AFM, to reduce the magnitude of the air flow signal peak, to reduce the amount of fuel that is added per revolution.
    • If you're dodgy you can try using a slightly finer grit (2-300) sandpaper on the belts ribs to remove the glaze from the pulleys.  Worse case scenario, you still need new belts and wasted an hour scuffing them up.   To confirm its the belts, if you have access to some, you can try dry lube. If they shut up for a minute or two, it's most probably as above.
