Need Cvt Oil (a.k.a Liquid Gold!) For The 80k Major Service
Maybe this will help all those new to V35s....
V35s came in:
1. 6 speed manual
2. 5 speed tiptronic auto
3. 8 speed CVT tiptronic auto (only made for V35 sedans, Series 1)
If you don't have a CVT, your 5 speed auto will take on the generic auto transmission oil (readily available). If you have the CVT, it needs a not-so-readily-available auto transmission oil....
Correct me if I am wrong (could well be) but I thought the Autos came out as 4 speed automatics, not 5 speed? I don't think mine is 5 speed as the tiptronic/manual mode only goes to 4m..
Also regarding the automatic transmission fluid, it may be OK to use standard ATF fluid (such as Dexron III ATF), but Nissan strongly recommend using their Matic J ATF according to the factory log books, use of any other fluid voided AT warranties in Japan. May just be a marketing ploy for them to sell their own branded fluids but not sure if I want to take a risk on it.
Iv been thinking of getting my gearbox oil changed as my cars clocked over 60k with the 5 speed auto. Was wondering if I should take it to nissan and get them to do the change with their oil. Or ignore the warning sticker on the dip stick and put regular slushbox oil in... me thinks the nissan oil change will be less than a new gearbox if non nissan oil wont cut it.
So are the 5 speed autos as fussy as the 8 speed ones with their drinking habbits?
Edited by 180 wanabe
The normal autos only came out as 5 speed, don't know where your other gear went, maybe Al Qaeda is holding it hostage.
Regarding the transmission fluid, forget about the conspiracy theories and devious plots designed to get your money, just get what is recommended. Why would you get any other, just to save a couple of dollars? And if so, what are you going to do with money you save, buy a Kit Kat? Well you'll be walking to the shop to buy that Kit Kat when your transmission fails, haha.
Edited by GoldV35
does anyone know what the 300gt or 250 have in the auto, think they may have been a 4 speed?
Easy Tiger, do you have a 300GT?
Yes, the 250GT and 300GT come out in 4 speed, but doesn't Easy Tiger have a 350GT?
Ok...I had to pull out my Skyline bible to set the record straight.
M-Atx (4 spd Auto) = 250gt, 250GTm
5M-Atx (5spd Auto) = 300GT, 250GT Four, 350GT Coupe & Sedan
CVT-8 = Only 350GT8 sedan
6Spd Manual = 350GT sedan & Coupe
Reference (Hyper Rev Vol 89)
I've got a 300gt and 350gt sedan, both are 5spd Autos. I assume Easy Tiger has the 4Spd Auto in the 250gt.
Certainly food for thought. I did notice today I was driving behind a new Murano which had the CVT transmission. With this Murano being brought in by Nissan Australia, does this now mean that the CVT fluid can be purchased locally with less hassle than it seems to have been so far?
no they're not, Murano CVT is designed for AWD, while the one they had on some high end Maxima is designed for FWD...
so that makes it difficult as the only RWD they sell in Aust is 350Z and no 350Z came with CVT...
I read somewhere the fluid is different too,but i could be wrong.
Guys, look at post #11 in this topic, I have put all the info there.
ive got no idea in my cars transmission. all i was trying to say is isnt the 350z auto trans same as the coupe auto trans im not comparing to the sedan. sorry if im making you guys fustrated if not the same then what is the v35 auto trans called and what is the z?
you need to get your facts straight...
V35 Coupe 5sp AT Transmission = 350Z Transmission
350Z early 5sp AT transmission <> 350Z later transmission, thus same case with V35 early <> V35 later
V35 Coupe 5sp AT = V35 Sedan 5sp AT
V35 Coupe 5sp AT <> V35 Sedan 8sp CVT (8sp CVT only offered in 350GT-8 sedans)
maybe i put it in the wrong words last time about cvt etc. the only reason why im asking again is that i was going to buy this http://www.skylinesaustralia.com/forums/5s...to-t279920.html but after reading this thread some of you guys saying its not the same?
The ebay link in that thread refer to '05 update 350Z 5sp AT transmission
so it probably will not work if your V35 is an 03-04 model. It will only work with V35 '05 or above
 Share
