Maybe this will help all those new to V35s....
V35s came in:
1. 6 speed manual
2. 5 speed tiptronic auto
3. 8 speed CVT tiptronic auto (only made for V35 sedans, Series 1)
If you don't have a CVT, your 5 speed auto will take on the generic auto transmission oil (readily available). If you have the CVT, it needs a not-so-readily-available auto transmission oil....
Correct me if I am wrong (could well be) but I thought the Autos came out as 4 speed automatics, not 5 speed? I don't think mine is 5 speed as the tiptronic/manual mode only goes to 4m..
Also regarding the automatic transmission fluid, it may be OK to use standard ATF fluid (such as Dexron III ATF), but Nissan strongly recommend using their Matic J ATF according to the factory log books, use of any other fluid voided AT warranties in Japan. May just be a marketing ploy for them to sell their own branded fluids but not sure if I want to take a risk on it.
Iv been thinking of getting my gearbox oil changed as my cars clocked over 60k with the 5 speed auto. Was wondering if I should take it to nissan and get them to do the change with their oil. Or ignore the warning sticker on the dip stick and put regular slushbox oil in... me thinks the nissan oil change will be less than a new gearbox if non nissan oil wont cut it.
So are the 5 speed autos as fussy as the 8 speed ones with their drinking habbits?
Edited by 180 wanabe
The normal autos only came out as 5 speed, don't know where your other gear went, maybe Al Qaeda is holding it hostage.
Regarding the transmission fluid, forget about the conspiracy theories and devious plots designed to get your money, just get what is recommended. Why would you get any other, just to save a couple of dollars? And if so, what are you going to do with money you save, buy a Kit Kat? Well you'll be walking to the shop to buy that Kit Kat when your transmission fails, haha.
Edited by GoldV35
does anyone know what the 300gt or 250 have in the auto, think they may have been a 4 speed?
Easy Tiger, do you have a 300GT?
Yes, the 250GT and 300GT come out in 4 speed, but doesn't Easy Tiger have a 350GT?
Ok...I had to pull out my Skyline bible to set the record straight.
M-Atx (4 spd Auto) = 250gt, 250GTm
5M-Atx (5spd Auto) = 300GT, 250GT Four, 350GT Coupe & Sedan
CVT-8 = Only 350GT8 sedan
6Spd Manual = 350GT sedan & Coupe
Reference (Hyper Rev Vol 89)
I've got a 300gt and 350gt sedan, both are 5spd Autos. I assume Easy Tiger has the 4Spd Auto in the 250gt.
Certainly food for thought. I did notice today I was driving behind a new Murano which had the CVT transmission. With this Murano being brought in by Nissan Australia, does this now mean that the CVT fluid can be purchased locally with less hassle than it seems to have been so far?
no they're not, Murano CVT is designed for AWD, while the one they had on some high end Maxima is designed for FWD...
so that makes it difficult as the only RWD they sell in Aust is 350Z and no 350Z came with CVT...
I read somewhere the fluid is different too,but i could be wrong.
Guys, look at post #11 in this topic, I have put all the info there.
ive got no idea in my cars transmission. all i was trying to say is isnt the 350z auto trans same as the coupe auto trans im not comparing to the sedan. sorry if im making you guys fustrated if not the same then what is the v35 auto trans called and what is the z?
maybe i put it in the wrong words last time about cvt etc. the only reason why im asking again is that i was going to buy this http://www.skylinesaustralia.com/forums/5s...to-t279920.html but after reading this thread some of you guys saying its not the same?
you need to get your facts straight...
V35 Coupe 5sp AT Transmission = 350Z Transmission
350Z early 5sp AT transmission <> 350Z later transmission, thus same case with V35 early <> V35 later
V35 Coupe 5sp AT = V35 Sedan 5sp AT
V35 Coupe 5sp AT <> V35 Sedan 8sp CVT (8sp CVT only offered in 350GT-8 sedans)
The ebay link in that thread refer to '05 update 350Z 5sp AT transmission
so it probably will not work if your V35 is an 03-04 model. It will only work with V35 '05 or above
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
