Master Power Turbos ?
I'm no turbo expert. It seems strange that race teams in the US are building big hp engines with top dollar internals and then bolting on what seems like a cheaper budget turbo. Some of these are making 1200hp, running big boost, pulling 8 second quarters and are happy with the performance and reliability of the Master Power turbos.
Supposedly several years ago a Chinese company sold a batch of cheaper knock offs and it has tarnished the genuine products name. This makes it hard to find reliable feed back as a majority of people in the US are extremely happy with the turbos. Some have done 30, 000 - 50, 000 miles and over 50 full passes on the strip with no issues miles while others won't touch them maybe because of the knock offs bad reputation.
It is reported that Master Power has been making turbos since 1966 and have one of the most modern manufacturing facilities available (video of factory below). It would be great to hear from anyone in Australia who has run the genuine turbo.
http://www.youtube.com/watch?v=CfQks3Yu6Gk
If by "cheaper" you mean not over priced, then yes. People need to get out of the mindset Garrett (including 3x as expensive re badged HKS crap) is the only good turbo out there. I'm not knocking garrett. GT series are great turbo's. There are turbo's that perform just as well if not better with the same reliability and probably better, that are a lot cheaper to buy/rebuild. I would love a GT40, but I wouldn't pay for one.
Its worth looking into the Garrett non-ball bearing turbos too - they are rebuildable quite cheaply and probably competitive with the Masterpower turbos :D If I were looking at saving dollars I'd go a Holset.
I dont think the problem is quality with the master power turbos,
Its the Shit house, Housing / Wheel Combos that they use, I would consider buying one if they didnt look like they were going to be LLLLAAAAAAAGGGG monsters
That's a definite draw back to holsets. The are BIG. If you are already top mount or planning on gonig that way, problem solved (unless your planning a HX52 like I've been considering).
What stuffing around? might take a bit of home work to find out what thread sizes are needed or the dump flange.
For Eg, I have a kkk K27 turbo off a 930 Porsche, the oil feed is identical to a plain bearing old school T3 Garrett, the oil drain is off the stock Rb25 turbo and the dump flange is a slightly modified GT30 4-bolt thing.
And you dont have to worry about making up water lines.
Just block the water feed from the block with a 14mm sump plug and block the feed from the back of the intake manifold, (or in my case i didnt have to do that due to using a Grdddy copy plenum)
Yeah, I wouldnt even consider trying to use a Holset / KKK / Master Power turbo on the stock manifold, AFAIK all the master power ones are Ext gate anyhow
In the thread about fitting a Holset turbo (I think it was a HX40 into a Cefiro or something), the guy doing it had to fab up bits here there and everywhere to get it to mount on the standard manifold, which kind of negates the low price of the turbo in the first place.
yeah I know the one you are talking about, like I said I wouldnt try and fit one to a standard manifold, Top-mount is easy, because unless you buy a complete kit it all has to be done.
my setup cost 1200-1300 bucks, I did the work myself which saves a lot, I think if it had a shop do it the costs would be similar to a "normal" Garrett high mount option.
Completely agree zebra. If you are high mounting, everything would be the same except for the price of the turbo, so if it costs you $4k for get a GT35r top mounted and installed with all the parts and bits included in the price, it would probably be $3k to do the same with a holset (just a rough example). If you are trying to low mount and you aren't handy with a welder, I think the holset idea looses a lot of it's luster. Nobody uses the stock manifold for anything other than bolt on type of turbo's here, so I never really consider that as a viable option for holsets when I talk about how cheap they are. Now if you just popped your top mounted GT30r/GT35r and are looking for an upgrade/cheaper option, a holset would be ideal.
  • 4 weeks later...
Has anyone used or have any info on the Brazilian made Master power turbos. Obviously they are no substitute for a Garrett. They seem to have a reasonable reputation in the states especially among the twin turbo mustang guys, considering their budget nature.
I'm actually the sole Australian Distributor for Master Power turbos.
They're great turbos for the money and we've got some fantastic results. Pulled 550rwhp out of a 700hp rated turbo on a RB25/30 in a VL turbo. It ended up running a 10 second quarter first run in full street trim including tyres and then got kicked off for not having a cage or parachute. This car is having some major work done to it at the moment and should be out on the track in the next few months. We've also got a few drift guys running them now with great results (Robby Mountfield - RB25 and Eugine Arendsen - RB25/30 setups). They've also given them a good thrashing running high boost and high rpm and hasn't missed a beat.
I've got my current stock advertised http://www.calaisturbo.com.au/showthread.php?t=174992 and our website will be updated in the next few days with our latest stock which arrived last week http://www.expressparts.com.au/master_power.asp
As for the "they're chinese crap" etc this is NOT the case. They seemed to have been branded with the chinese ones a few years ago when a few different chinese turbos came out such as XS Power, Monsta Turbos etc etc. They're made in Brazil and the company was established in 1966. They also have ISO 9001:2000 certification which is for their quality assurance systems and procedures in their manufacturing. Master Power back their turbos with a 12 month manufacturers warranty.
I saw one of the posts commenting about the thread sizes etc. All studs on the Master Powers are M8 x 1.25mm, the oil feed is M10 x 1.0mm (on all turbos except the GT45 frames), oil drain is same as Garrett and all of which I keep in stock. They don't use waterlines so you just block them off on the block.
I'm working with Master Power at the moment to develop turbos which are internal gated that bolt straight onto SR20 and RBs. These are probably a good few months down the track by the time MP develop everything in house and then we test them on a few cars. They do currently produce a few internal gated turbos but I don't bring in......hopefully that will change shortly though!
With their wheel sizes, their new designed turbos are good. On Robby's RB25 the T60 was making 18psi at 4300rpm and made 400rwhp with a very usable rev range.
Any questions feel free to email me [email protected] because I don't get on here too often.
Cheers
Will
  • 7 years later...
I remember there being some conversation about these things years ago and they seemed like a viable option from their international reputation etc, but not that many people in our (NZ/Oz) neck of the woods really wanted to be guinea cops so results are quite thin on the ground.  I never recommended them as the range at the time of this thread was ultimately based off replicating Garrett T-series wheel designs which guarantees results representative of an obsolete design.
Anyway, over the last few years Master Power have started designing their own wheels - complete with flow benching them and supplying compressor maps etc, a couple race cars which I tune have been using their 59mm billet "R595" turbos but with moderate tunes which aren't going to do them much justice so we've treated them as an affordable reliable thing that "just works", though one of the guys did some changes and wants to hit the strip at some point to shoot for a solid 10 so I was instructed to "wind it up" so did just that and was pleasantly surprised - so figured it was time for a thread bump :)
The performance related stuff is a stock (aside from head studs, rod bolts and head gasket) R33 RB25DET, FReddy intake manifold, Sinco exhaust manifold, Master Power R595 with .63a/r T3 exhaust housing, and a 600x300x100 Fenix intercooler -  it's running on E85.
Here are the details for the turbo in question:
Here is a compressor map and details for this particular unit:
Compressor: 59 inducer, 84mm exducer, 49Trim Forged CNC Aluminium
Turbine: 59mm exducer, 70mm inducer, 71Trim 12 blade
Core: MP350 360 Thrust, LI journals, Water cooled
And the NZ supplier we've used so far: http://www.frantik.co.nz/MasterPower-Turbos.html
http://www.frantik.co.nz/Resources/MP%20R59%20Compressor%20Map.jpg
And the result - I kept winding it up until I started encountering hints of any restriction coming into play and it was at about 23psi where it started getting a bit "over it" so this is getting near "all in" for that exact combination.
On 1bar the thing opens its gate in the low 3000rpm, its opening here at around 23psi before 4000rpm - it's the best power delivery I've seen on an RB25 making this kind of power on this dyno, and it's quite up there in general I think.
Thought this may be interesting, so far they've seemed reliable enough etc though I've not really had too much exposure other than these two guys and a made running a slightly smaller one on his Honda.  They've all "just worked" so far, and we've been pretty impressed with the response for a cheap (~$1000NZD) turbo but getting an indication of the power they can deliver has made me think they maybe shouldn't be completely overlooked.
Edited by Lithium
  • Like 2
Since the tune this car has done 2 hillclimb events, the first one it came second overall - the second one it won outright.
Here's a clip from it's first timed run at the first hillclimb, he's able to cover large parts of it just using 3rd gear... at times getting quite low in the rev range and still being able to pull quite briskly out of corners which I thought was decent for a reasonable flowing journal bearing turbo.
  • Like 3
 Share
    • Hey Matt, Link pointed to the 2x IGN power sources from the car as a likely issue, and sure enough pin 31 in the loom does not have power when IGN is on (24 does). So at the ECU, (and this is probably the case for R32 as well as C34) most of the ECU loom goes through the firewall behind the blower motor and there are 2 plugs (of 3 in the junction box) which go up and under the dash, the third plug heads under the carpet to places unknown (likely a body to dash loom joint) So, I started to follow that problem through yesterday. Like Johnny (and R32) I assumed that power was supplied through the 2 connectors near the left headlight so I spent some time pulling the intake etc off and cleaning of 400,000klm of dirt and oil leaks and checking those pins, but there was nothing related to the engine parts or ignition fuses there (and no purple with white trace wire in either side of the connectors) Given that the wire didn't seem to go via the engine bay, I then checked there is continuity from Pin 31 to the second connector to confirm no wiring issue in the ECU loom (it looked likely, given how much that has been hacked up over the years!). The pin marked with the purple dot is the other end of the wire to Pin 31 Then I check for IGN power in the dash loom side of that connector with the key on. Nothing. Given that loom goes up and underneath the top of the dash there is no tracing it without taking the dash out, so I went to the driver's side to see if I can find the other end of that (I'm expecting to get to big body junction boxes after I pull enough apart). However, to get to those functions, I had to pull the covers off the drivers side, I'm pretty sure the problem is in this pic Yep, factory remote start (bottom right), local immobiliser (middle) surrounded by 20 years of butchery. Plan is to totally remove the remote start and immobiliser (I think I will lose remote central locking temporarily as a result) to remove all the suspect stuff given I have other more modern security in the car It's gonna take a while, and it is both cold and uncomfortable out in the shed, not looking forward to it.
    • Hey team,  The clutch on my newly bought 25 swapped r32 feels average and sticks half way. Went to go order a new clutch master but it does not look like the ones that suit the one that’s in the car…    does anyone know what clutch master is this just by looking ?  (The feed is on the side rather than the bottom like the ones the pop up online)  thanks guys new to the RB scene so any help is appreciated cheers !!
    • Id be more than happy to sign up!!! Where do I send the invoices for my fuel usage? I'm happy to provide the mower, oil, and the labour to abuse the motor, just a little help on fuel would be great...   I had tipped the container of oil out into my big "drip tray" and left the small container upside down to drain the oil out of itself overnight. PIcked the container up today, and it has a layer of what feels like either dirt, or shit tonnes of carbon in the bottom of the container. I'm leaning towards it likely being dust, as I doubt the quality of the Sunli BumbleBee having a decent air filter on it, and sections of my yard produce a dust storm, especially because of the high lift blade!   So, filled her up with some fresh Nulon. Seemed to run fine, but it seems to want to run at really high RPM (higher than normal) even with the governor spring slacked off after fire up to try reduce it. If I back the throttle off it a bit to drop the rpm to where I'd like it to be when mowing light grass, it starts to blow a bit of smoke out the exhaust. Opening the throttle back up clears that out. It's definitely breathing oil, as I put my hand down at the breather hose and it's spitting some oil.   My guess is it having been running at high rpm, oil never changed, and it eating dust has destroyed the rings. You know what that means? Time to send it!!!
    • That is what will seal with the bonnet closed. Follow it down while closing the bonnet to see where it ends up with the bonnet closed. The panels don't do anything other than spending money, which this one will do just fine. :p
    • Nah just send me a photo or a drawing and I'll tell you which is better.  It's a new SAU service.
