  • 3 weeks later...
A RB25 powered GTS4 circuit car running a .82a/r R595 - I didn't really mention that because the car does circuit racing, not time attack but actual laps and laps of racing on stock bottom end and 98 octane so I wasn't really squeezing out it's full flow potential on the dyno... everything was done to ensure he could rely on it for laps on end.   It made ~295kw @ hubs on 98 octane at around 16psi, hitting target by around 4000rpm.
Another was an R545 with a .82a/r housing on a Honda F20B engine (2litre twin cam VTEC, a bit like a destroked H22A) in a Honda Accord.  That only had ~540cc injectors so was not making big power either, but was making good boost by 4000rpm - again another one I never got specific on because the turbo clearly had plenty of flow to spare, the power figure (just over 200kw @ hubs on ~10psi) wasn't going to do it justice.
thanks for the reply mate.  i was looking at either the r595 or r545 for an unopened sr on 98 with around 18-20psi down its throat.  i like the 59/59 r595 wheel match a bit better than the 54/59 r545, but it would be fairly laggy id imagine.
What power are you aiming for, with what fuel etc?  Stock cams?   One of the things I tune has been running a Kinugawa TD05-16G6 with the 3" intake (TD06 style compressor) for the last few years - completely stock internals (including cams), and flex fuel on up to 20psi. Honestly, it is an amazing match imho.    I know it's not a Masterpower, but it works so well I don't know why you'd go for something different - especially if you are running with an external gate.  The thing can hit 20psi+ at around 3000rpm in higher gears, and has trapped at around 120mph in the 1/4 mile - is pretty rapid.
Edited by Lithium
as above,  around 18-98 on pump 98 fuel.  unopened so yeah stock cams.  e85 is only available at a couple pumps in perth so im not really looking to go down that route.  my old car did 119-120mph passes id be pretty happy with that haha.  350rwhp would be nice,  so whats that around 280rwkw or there abouts?  makes 270rwhp on a disco pot at the moment and 110mph. and yes will be external gate.
Hang on - you are running a discopotato on 20psi already?
I'm kind of inclined to think that there probably isn't a huge amount of point in upgrading the turbo and running 18-20psi without doing cams, the cams are potentially the limiting factor in your setup at the moment I'd have thought.    280kw @ wheels on 20psi with pump gas on stock cams sounds pretty optimistic, regardless of what turbo you use.
I guess I haven't had HEAPS to do with SR20s, but they seem like they aren't that great on stock cams - at least from what I've seen so far a GT3076R would be a waste as you'd make well short of what they are capable of on 20psi but get heaps more lag.   For what it's worth, even with the 16G on 20psi the turbo seems to have more flow available
  • 3 weeks later...
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
