^ What Bec said :)
Committee meeting tonight, so the list should be updated in a couple of days with tables that we have thus far.
but PLEASE PLEASE - Make sure you send the email - makes it soooo much easier as a few payments we've had to track down
  • Replies 212
Posted Images
Ok - Following a rather slow uptake.
The SAU-Vic's 5th Year Gala Ball is now...
OPEN TO THE GENERAL FORUM/PUBLIC.
Price is still $100 for non club member, same as previous posts etc etc.
Yes, this means anyone off the forum can come along for a great night.
Yes, this also means if you are a Vic Member, you can bring alone 2-3 more friends and no longer just a "+1".
We will do a full table update on Friday, there have been a good number of payments coming in this week, so don't wait too much longer :D
Thanks.
Prizes updated (for the charity raffle).
More updates to come as more raffle prizes are 'in the wings', just not 100% confirmed yet
1x Meal Voucher for Bells Hotel - Approx value $50
1x Import Monster Credit. Value $200
1x General Maintenance Kit from Status Gearbox & Diff. Value approx $150
1x Dyno Power Run - Racepace Motorsport. Value $160 (RWD or GTR only)
1x Meguiars Pack - TBA Value (approx $100 i believe)
Charity Raffle prizes updated again (more to come)
1x Meal Voucher for Bells Hotel - $100
1x Meguiars Pack Waterless - $100
1x Meguiars Pack Water required - $100
1x Citywide Towing Voucher - $100
Total: $910
Its growing!
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
