  • Replies 212
Posted Images
We will be taking cash payments at the General Meeting tomorrow night as well….
Forgot to stick that in the recent mailout! :P
I will buy a ticket tonight at the meeting
I think Leon will grab 4 tonight aswell..
Keep rolling in payments guys!
Remember, YOU ARE NOT MARKED DOWN AS IN ATTENDANCE UNTIL YOUR PAYMENT HAS COME THROUGH. We need to get a move on with the numbers just to save this event, so PLEASE get your payments off ASAP...it will not count if you simply promise payment at a later date!
All, as discussed @ the General Meeting...
As of Monday 21st Sept - the club needs to make a call about cancellation.
As it stands, we are 30 people away from the minimum number requirement... So please get the payments in before Monday as this is when we make the call.
We had a solid number of people in the EOI thread, however they all seemed to have gone quiet :happy:
If the event does not go ahead, the club will loose between $2,000-$3,000 which is the booking deposit, overall the event is costing nearly $10,000. So this is not a small money event!
(of course, full refunds will be provided if the event is canceled)
So i urge you - if you are paying, do it ASAP so come Monday we can keep this going ahead!
I'm all paid up, me on my lonesome. Please put me on a table with Hamish and Merowyn if possible.
To my knowledge they are on our table which is full :happy:
They haven't paid up yet though so you could always convince them to be on a table with you? Or get put on a table right next to us? I don't mind who I sit with to be honest.
You can all meet with me and talk to me and regail your stories of my ex-beasty vehicle.
We will drink, be merry and if you are on point, we can be hilarious!!
BASS OUT
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
