post-61423-1249980284_thumb.jpgpost-61423-1249980357_thumb.jpg[attachmen
t=239517:18072009006.jpg]post-61423-1249980842_thumb.jpgpost-61423-1249980976_thumb.jpgpost-61423-1249981064_thumb.jpgpost-61423-1249981147_thumb.jpgpost-61423-1249981223_thumb.jpgFor sale, Alcon 4 piston and 320mm rotor brake setup for R32 GTR,
Thick long endurance pads with plenty of pad left, high heat pads.
Rotors, 2 peice slotted rotors, 320mm diameter, 36mm thick curved ventilated rotors. Cleared 16inch enkeis, but not sure whether they would clear std R32 GTR wheels(caliper clearence) Could probably modify to fit bigger rotors on if you required
Come complete with rotors, calipers, pads, braided brake lines and the spacers, just bolt on and go.
All setup to suit R32 GTR, one small modification needed to hub assembly to put on.
Awesome brake upgrade, would suit targa/ track days etc, worked very well on my car
Call me or pm if you wish to discuss 0438911374
Oh yeah they can be yours for $2000
Michael
Anyone???
Will consider a layby sorta setup if anyone is keen but dont have the cash straight up, i did it with my turbos for a member of SAU as he couldnt come up with the money all at once. He payed them off over 4 weeks and i sent the turbos to him when he had finished paying them off.
Edited by pointa32
    • Might piggy back off this thread since there's been a good discussion about PWM.   I purchased a Walbro 460 F90000267 and have been looking into PWM to understand it. It was purchased more of a future proof as my original OEM fuel pump died (r33 below 200kw) and figured I'd just upgrade it to this. That's when it hit me that a pump this big can cause more dramas with such high amperage draw and heating of the fuel pump being on 100% all the time in such a mild setup.   I have a Nexus R3 and slowly collecting power mods but I was looking into the PWM feature on the NSP software:   Then looking at the graph from the fuel pump:     Am I safe to assume reducing duty cycle to 50% for example would make the pump run like a 230/lph ? Where does the PWM come in all of this ?   I've gone down the rabbit hole of PWM fuel pumps and it seems there are many differing opinions on how to go about it 馃槄
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
    • Rear turbo is leaky, most likely at the oil drain. From what I could see with my boroscope it seemed to have seeped out at the very top of that return hose. Is it possible that the oil climbs up that hose to then leak out? Yup, coolant leak on the hot side of the engine, only noticed after seeing clear rusty residue in the block right from the turbo oil feed downwards to the pan, and red droplets hanging from the pan. No clear sign yet from where it comes, and most of the lines there are hardlines right? Last year, seeing those red drops, I thought it was power steering, will be glad if that is not leaky at least. Another leaking hose I found by chance is the lower of the two heater core hoses coming from the firewall to the back of the head. That one is not too bad to get to if I have to replace.
    • I think for response I'm already kind of out there no? he -5s are not the best pick for that as the Internet tells me. Maybe I should switch to -7s while I still can? Though that almost definitely warrants an engine pull along with the other issues I have.
