yeah the photo is in shelbyville but I live in the stanes and toonie is like 2 minutes away Hehe :D
I've only seen a white one in Greystanes I spotted a couple but been to far away to catch up... Some hot bird driving a white one around north rocks
https://www.sau.com.au/forums/topic/282947-my-stagea/#findComment-4762603
I need someone to fill me in on the cars!
What's a s and why is it different?
Would love to come for a cruise as I've spotted a few around. Usually not wearing my glasses so can't see what type they are :)
Got a problem with the power window drivers side auto switch. If you use auto to wind up it hits the top the automatically goes down half way again
https://www.sau.com.au/forums/topic/282947-my-stagea/#findComment-4771937
You've got an auto *up*? You lucky bugger...
https://www.sau.com.au/forums/topic/282947-my-stagea/#findComment-4772023
