  • Replies 68
What specks did Kip build it to?
I asked for the biggest wheels that would sensibly fit, on a bush core. Very similar to the skyline rebuilds he does. It could be good for 250? Im not sure the box would take it though.
https://www.sau.com.au/forums/topic/282949-atp-highflow/#findComment-4762187
the box should be fine
,mine is all a-ok with 240rwkw
and I expect the auto to be as fine with another 25rwkw thrown on top
over time it may get a little loose, but nothing like changing a clutch every few yrs
perhaps in a decades time she may need a rebuild or strengthen up but that'd be about it.
service it regularly with good fluids along with shift kit and you'll be alright
nice turbo. bush bearing tho? went from bush highflow "2530-size" to ball bearing highflow "2835-size", massive difference in power delivery
https://www.sau.com.au/forums/topic/282949-atp-highflow/#findComment-4762199
Im not sure which box is in the 34's, are they the same as M35? Mine was slipping badly when I took it in, needed a full rebuild with extra clutches fitted and valve body. Kewish are not sure it can take that much at the wheels.
Main problem with the ball bearing cores seems to be the excess heat in such a confined spot under the engine. I am hoping to get good life out of this one.
https://www.sau.com.au/forums/topic/282949-atp-highflow/#findComment-4762436
scotty,
That looks great.
Do you know how big it is built, ie. Gt30 or Gt25. It looks a bit smaller than Danny's.
Can you say what the cost was?
Cheers
Andy
Its about gt30 size, not that ive seen one close up. It would be about 2 inch inlet I guess.
All we can go by is what those same wheels punch out on an rb, around 250awkw. Im sure with the weird standard exhaust manifold, there will be more restriction.
I guess we will see the outcome soon, I will have to get it back on the dyno straight away.
Edited by scotty nm35
https://www.sau.com.au/forums/topic/282949-atp-highflow/#findComment-4762548
well, one is a 4 speed, the other is a 5 speed to begin with. i dont think jatco made the C34 box either, whereas they manufactured ours.
Pretty sure Nisaan have been using Jatco boxes in Skylines/Stageas since S3 R31's
https://www.sau.com.au/forums/topic/282949-atp-highflow/#findComment-4763723
whats similar is that they are auto stags with highflows....... its all the same basic principles / theories.
S1, S2, M35, all stags with the varied stagea features, auto boxes are auto boxes, and high flows are highflows. again a variety in types..... :)
https://www.sau.com.au/forums/topic/282949-atp-highflow/#findComment-4764035
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
