Aem F/ic-8 Piggyback Ecu
Tangles
 Share
Hi
I am buying a AEM F/IC-8, new but ebay 2ndhand, for $350USD delivered.
Usually around $750USD delivered.
http://www.aempower.com/ViewCategory.aspx?CategoryID=116
FEATURES
Injector Channels
Advanced Injector Load Simulation & Filtering
Timing Channels (Cam + Crank) 5
High/Low Voltage Selectable MAG-Driver Outputs
TPS Input
MAP Sensor (Onboard)
MAP (0-5v Intercept)
MAF (0-5v Intercept)
Frequency Based Flow Meter Support *
Speedometer Recalibrator *
o2 Sensor Remapping
External AFR Input
Generic 0-5v Remappers 2
Boost Controller (Requires AEM 30-2400 Solenoid)
IAT Logging Input
PC Datalogging
Internal Logging Memory 2 Mb
VTEC Output/Control/+12V Switched Output
http://tunertools.com/prodimages/AEM/manua...30-1910_FIC.pdf
http://tunertools.com/prodimages/AEM/manua...for_30-1910.pdf
It runs a map system for fuel:air, ignition timing, and injector duties.
21 x 17 maps, for these 3^, via laptop tuning.
that should be an Excellent scope of tuning for an automatic RB25 to reach 265rwkw
Query : Does anyone use the AEM F/IC? Or have they seen it being tuned?
Looks pretty good, and should do the trick to run aftermarket bigger injectors (S15 JDM 450cc), as well as allow a much better 02:fuel / Ingn.Timing tune due to the map size, over a conventional piggyback setup such as SAFC + SITC
By the way I have a Toshi tuned ROM ECU chip but cant afford a new chip tune, same price buys this AEM F/IC-8 so Im going this way.
Anyone have any thoughts?
OVERVIEW
The F/IC gives users with OBD-II race vehicles and non-factory forced induction systems the ability to retard ignition and deliver accurate amounts of fuel without the need for outdated FMUs or “boost hiding” controllers. This system works parallel to the factory ECU preventing tuning limitations due to complex factory timing patterns. 21x17 maps with configurable load and RPM breakpoints are easily accessed with the F/IC's Windows-based tuning software. The F/IC draws power from PC USB interface for quick and easy calibration changes.
PRECISE FUEL DELIVERY
The F/IC intercepts the signal to the stock injectors, allowing the user to modify pulse-width by +/-100%. The F/IC is among the only piggy-back systems that can decrease injector pulse-width, allowing the user to drive larger aftermarket injectors* while still maintaining proper air / fuel ratios. This powerful system can also tap into the factory injector signal and work independently to drive up to six (6) additional injectors.
TIMING RETARD CONTROL
The F/IC can retard timing from the factory system based on engine RPM and load inputs. This is achieved by intercepting and delaying the outputs from the cam and crank position sensors to the engine- with no adverse affect on applications equipped with variable cam timing.
SENSOR CALIBRATION & CONTROL
The F/IC can also be used to recalibrate / clamp the MAF sensor, eliminating common problems with non-boosted factory MAFs. The on-board MAP sensor allows for proper fueling in boosted conditions.
CAN-BUS SYSTEMS NOT AFFECTED
Since the F/IC works in conjunction with the factory ECU, late model-vehicles equipped with a CAN-BUS system retain functionality of climate controls, dash and other components on the network.
I use AEM stand alone ECUs and Love them, Downside is their way to complex for most Tuners.
Never used your setup but judging the Full ECUs Id think it will be great if you have a good tuner.
best advertising to say why not to get one right there!
The AEM standalone is a good computer.
I have it on my turbo honda S2000. It's very userfriendly.
MD tuned a couple of s2k with the AEM ecu.
The AEM F/IC piggyback is still in the work and "had" a lot of issues for some cars.
I have not look at it for some time and I am not up to date with this unit.
They might have sorted out the issues but it is still a piggy back unit and for the price, why not shop around for a used Emanage Ultimate.
no issues with the ecu, dont know the first thing about it. a great feature list is great if you need those features
just be wary how many people can tune it and if its plug and play or mange your loom install
if theres only 1 or 2 workshops who can work / tune it and you dont like their pricing, waiting lists, service etc, you got nothing
its the same as HKS FCON and some of the other high end ECU's
sure awesome, does everything, top of range. 1 tuner. awesome
this car is a 20yr keeper, so its all good in this instance.
windows-based tuning, maps of fuel, ignition & injector pulse shouldnt be rocket science, and software is readily available
awaiting a $120 ebay-special 2ndhand laptop which will reside in the car, for tuning.
I imagine over time I'll be fiddling with settings myself, and my current mechanic is more than competent
  • 3 years later...
Been faultless since installing. A good option as a piggyback if you've got access to a great tuner.
Will finally do a power tune mid year with the forged bottom end.
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
