Item: Greddy Profec A electronic boost controller EBC
Website: Boost controller
Item Condition: used but still good
Reason for Selling: no longer needed.
Price and Payment Conditions: $250
Pictures: one below, see link for more
Contact Details: PM or post here
Hello there ..
This seems to be a nice old school controller.
Could you tell me a bit about the features?
Does the unit display the current boost?
And does it display the max peak boost reached?
How does this overtake boost feature work?
Cheers,
Andrew
Edited by Torques
