Hey all hopefully some one can help me.
I have a Alpine Type R 12" sub, Cadence FXA 1500 amp (500wrms @ 2ohm), 2ga wiring, Response 1 farad capacitor.
Problem is when i adjust the gain i get a rattle noise coming from the sub but only when its mounted (had to modify a box for it to fit) when the sub is out of the box it doesnt rattle at all. I bought the sub in a alpine enclosure but having a R32 the boot isnt accomidating to the box. Even when i put the sub back into the original alpine box i get the same rattle. I have checked all my cables and they are all fine (well they look fine).
As it works fine out side of the box and if its slightly lifted out of the box is this a sub issue or a box issue. The original box had quite a large port in it but the box i have now has a 4" port and 2x2" ports in it.
All of the parts are brand new and have only just been put into the car over the weekend.
Any help would be appreciated.
Thanks
Daniel
https://www.sau.com.au/forums/topic/282994-sub-rattle-noise-when-mounted/
Thanks
Daniel
might be easier to see in person, or photos, you tube to hear it ????
one thing I would guess right off is you dont have the port tuning right on the box to start with, and will destroy the woofer in the end if thats the case ?
porting sounds weird to me, but i'd say you've probably clipped it to death, or over excurted it. take it to your alpine dealer, they'll cut it open and tell you. if its a manufacturing fault, they'll replace it, if you've clipped the asshole out of it, or over driven it, then you have a new paperweight. only way unfortunately.
well it has doing it since day one when i installed it.we tried it in the box it came in which was from alpine and it did the same.it shouldnt be over driven as it can handle 500wrms peak 1000wrms and the amp says it only goes to 500wrms @2 ohm. if it was clipping it should do it when its not in the box? but it doesnt. its really confusing me lol.
if the port tuning was wrong on the box im guessing that could cause it,but it does it in the alpine box it came in?
well if the amp is only 500wrms it'd be easy to clip or underdrive the woofer. like i said, it's only something that can be found by cutting the woofer apart.
and unless the amp is rated 500wrms @ 12v @ 0.005%thd i'd doubt it'd make 500wrms.
Edited by Shiraz200SX
Where abouts are you located mate? if your in adelaide south i can put it through its paces for you and determine a problem with it if any.
Without hearing it personally it sounds like the spider is detaching from the cone, if it did it from day one it could be that the machine that applys the glue missed a spot or something.other than that the only thing that could make that kind of noise would be a problem with the VC,if that was the case it would have probly seised by now.if not it could be your amp introducing the noise.
Have you tryed the sub from another amp or in another car?
EDIT: Oh and 500 rms is more then enough to run the sub. Remember an amp is like a light switch it wont put all its power out as soon as you turn it on. VERY rarely would a sub see full out put from an amp unless your pounding on it consitantly.
And +1 to troys post.
Edited by Jack88
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
