I'm looking for work, the job I've got is taking me nowhere but backwards. I want to start an apprenticeship, something in the auto industry.
Eletrical, Trim, Paint or Panel, in that order, not really keen on mechanical. I check ApprentiCentre and Seek atleast once a day, which is sad.
Does anybody know of any apprenticeships for those trades, willing to take on a 20 year old, with a 2-4 week start ?
The closer to Midland, the better.
I know, until I hit 21 and adult wages it'll hurt, but thats a sacrifice I'm willing to make. $300 per week for 1 year isnt too bad, its not like I have anything to piss that money up on apart from my cars anyway.
If so, PM would be much appreciated.
or, email is [email protected], mobile is 0431 598 320.
Cheers
Nic
https://www.sau.com.au/forums/topic/283009-thinking-about-an-apprenticeship/
hey man, just some insight, if you have the smarts try going for an electrical apprenticeship, if you enjoy it there are hundreds of fields you can take and it generally pays better in the long run, im a first year on 500 a week so it should hurt you too much :huh: and i know alot of apprentices that are above you age so just show interest and you'll nail one :P
just found this...
To be entitled to an adult rate of pay an apprentice must be of the specified adult age at commencement of the apprenticeship. An apprentice who becomes an adult during the course of their apprenticeship shall not become entitled to applicable adult rates of pay
just found this...
Not all companies will follow that. A guy at my work was on $9 as a first yr then we all got a raise and he also turned 21 at the same time ended up on 9 one week and 25 the next.
Apprentices get paid pretty well I think. a 4th year at a good company will be on only slightly less than a tradesman.
tbh i've been thinking the same thing...
im 22 now and pondering going into automotive (in same way or form...)
basically got cert 3 and 4 in IT and half my diploma (bit bored of IT..) working in the mines but soon to be let go due to end of contract..and i want something to do with cars seeming as i <3 my car to death and want more to do with it lol if the starting wage for an adult is like 35k or something (or MORE?!) id be up for it haha.. besides...can you get worse than working 2 weeks on 1 week off 6am > 6pm in summer in the outback? lol
interesting though i didnt realise you could go to an adults wage and stuff...hrmmmm
5 till 8, in summer, with no air con... I would've died to have worked on the mines, but no, had to be a farmer's son lol...
A janitor aside, farming by far one of the most shocking jobs going around... Hence why I moved to Perth! :P
If You do look for an apprenticeship. Try the bigger and well known companies as they usually offer good wages and better working conditions.
I'm a 2nd year electrical apprentice, I really don't do much a lot of the time and I have very little responsibility :P
i looked into this a while ago, wageline say adult wage is min $460 before tax a week last time i called, but they said depends on the employer and obviously overtime and stuff. also think there may be some gov incentives to, but didnt look into that to far.
i know range ford are looking for apprentices atm, and they tend to favor mature age a bit from what ive heard.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
