  • Replies 54
  Puppey said:
Congratulation!
I remember the same excitement when I got mine last year
... The first smile on my face from driving a car ... :thumbsup:
Keep it well and it will make you a happy man! :thumbsup:
And that smile on the face every time you drive it will never wear off .. :(
Yep true that ! I had problem sleeping since the day I drop my deposit for the car until I
pick her up a week after. The way she moves makes me smile :thumbsup: and can't beat the turbos sound.
I remember the first day I was hopeless with the twin plates clutch. Dumping the clutch
at almost every traffic light at around 1.5k RPM :) Now i'm okay with twin plates :thumbsup:
Coming from a manual Corolla, this is way way better to drive, just a bit paranoid when I
park her out in a public car park :thumbsup:
  Panko said:
Don't be mate. I'll be jealouse when I can't fit my snowboard inside the GTR :mrt:
Still trying to fit my bloody snowboard !!
a mate of mine fits his bmx bike in the back of his 32 gtr lol
its an hilarious sight hahah
but my board is 157 cm I think now sure :mrt: it's quite long ! shoulda take the
pic of the bmx in a GTR :)
  bob san said:
Nice car man, Black GTRs look tough as.
Btw there is a fuel warning light when ur needle is sitting right on the empty line.
Cheers mate so I can find out how many Kms I get before the warning light.
I had to fill up before the warning light last time because I wasn't sure if
there's actually a warning light. Just to be safe :(
  Panko said:
but my board is 157 cm I think now sure :P it's quite long ! shoulda take the
pic of the bmx in a GTR :D
there's actually a warning light. Just to be safe :D
i hope you don't have a heavy right foot :D
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
