the lower mounting point of my rear shock absorbers are worn (the rubber bit which has the bolt going through it)
can you buy and replace that round bit of rubber?
my shocks are in good condition and quiet so i dont realy need to change them, would pedders or some store along those lines have them?
any info would be great !
https://www.sau.com.au/forums/topic/283039-rear-shocks-rubbers-are-worn/
The rubber is bonded to the shock in most cases
Tein use a pressed bush.
Bilstein use a slight rubber bond, and a much larger bush size fron stock.
Simply, its not that easy, Unless you can measure your stock shock eye and then matching up a urethane bush is still hard, as the factory bonded crush tube is tapered.
the lower mounting point of my rear shock absorbers are worn, shocks are in good condition
I don't think so, if there is enough wear that the rubbers are worn out then the shocks are equally as worn out.
Cheers
Garyt
