Saw a trailer a couple months ago. though it didnt show any in game stuff yet.. Been playing the original again to finish by saving the little sisters instead of harvesting them and decided to look up some more info on number 2.
It looks pretty good so far!
This time you are a Big Daddy, you can 'adopt' the big sisters or Harvest them, splicers are around but a lot easier for you to kill, they attack you in groups as well. And a new character is the Big Sister, similar to a big daddy but a lot faster and pretty powerful.
also a pretty cool thing about this one is you can go outside of rapture and in to the ocean surrounding it. You are apparently the first big daddy so you can still use plasmids.
pretty good demo
Also I havent heard any more news on the BioShock movie, though it's meant to be released next year.. any one got any info?
https://www.sau.com.au/forums/topic/283054-bioshock-2/
  • Replies 61
bah! looks like I decided to look up BioShock 2 info a week too late. Last weekend there was some Viral Marketing done around the world. Last weekend in Bondi a boat was washed up on shore with bottles of wine spread around it in the beach. The bottles contained maps and posters, all which are seen throughout rapture in the first BioShock game.
There is a website up called http://www.somethinginthesea.com/home.html .
What I have gathered so far:
the person who is in this room (Mark Meltzer) had his daughter kidnapped, he has been researching ryan and other people from the first game, he knows a bit about rapture but doesnt really know what it is. . . Little girls are being kidnapped around the world by what appears to be the Big Sister in the trailer of BS2. Mark had a run in with the big sister and ended up in hospital.. and a whole bunch of other stuff..
I'd say that Mark will end up in the game as some one that helps you through rapture or maybe out of rapture.. anyway.
https://www.sau.com.au/forums/topic/283054-bioshock-2/#findComment-4765268
  • 4 months later...
I'm getting a copy of this. Only played a few mins of the first one but was good. Still playing borderlands at the moment.
is borderlands any good, I've read plenty of reviews and gameplay footage...
But still don't know if its worth it...
https://www.sau.com.au/forums/topic/283054-bioshock-2/#findComment-5030023
I've been watching trailers for bio shock 2 and I cant wait. It looks goooooooood. :D
I've play Borderlands a fair bit. Its alright but it can get boring. There are millions of guns. I spent more time building up my arms then shooting them.
Worth a go if you have time to burn. Plus co-op mode is pretty fun.
https://www.sau.com.au/forums/topic/283054-bioshock-2/#findComment-5031621
re: Masseffect 2 i got this email today..
Dear Sam,
Thank you for your application,
Please head to Masseffect2.com.au for a more detailed briefing
And remember, we kill because we care
Yours Sincerely,
Commander Shepard
https://www.sau.com.au/forums/topic/283054-bioshock-2/#findComment-5034509
I was watching some updates for mass effect, at least one of the characters has an aussie accent, last time I played a game with aussie accents was halo, is it the new 'nondescript international accent?' for games or something?
ie; like when hollywood forces their actors to do terrible british type accents to make their movies 'continental'
https://www.sau.com.au/forums/topic/283054-bioshock-2/#findComment-5037521
yo
you can preorder bioshock2 on steam its 10% off and you get bioshock1 free $71 USD
even better use the US store and its only $44 USD
US store link
http://store.steampowered.com/?cc=us
jsut change your address to USA then change it back
NY post code is 10001
https://www.sau.com.au/forums/topic/283054-bioshock-2/#findComment-5044721
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
