Saw a trailer a couple months ago. though it didnt show any in game stuff yet.. Been playing the original again to finish by saving the little sisters instead of harvesting them and decided to look up some more info on number 2.
It looks pretty good so far!
This time you are a Big Daddy, you can 'adopt' the big sisters or Harvest them, splicers are around but a lot easier for you to kill, they attack you in groups as well. And a new character is the Big Sister, similar to a big daddy but a lot faster and pretty powerful.
also a pretty cool thing about this one is you can go outside of rapture and in to the ocean surrounding it. You are apparently the first big daddy so you can still use plasmids.
pretty good demo
Also I havent heard any more news on the BioShock movie, though it's meant to be released next year.. any one got any info?
https://www.sau.com.au/forums/topic/283054-bioshock-2/
  • Replies 61
bah! looks like I decided to look up BioShock 2 info a week too late. Last weekend there was some Viral Marketing done around the world. Last weekend in Bondi a boat was washed up on shore with bottles of wine spread around it in the beach. The bottles contained maps and posters, all which are seen throughout rapture in the first BioShock game.
There is a website up called http://www.somethinginthesea.com/home.html .
What I have gathered so far:
the person who is in this room (Mark Meltzer) had his daughter kidnapped, he has been researching ryan and other people from the first game, he knows a bit about rapture but doesnt really know what it is. . . Little girls are being kidnapped around the world by what appears to be the Big Sister in the trailer of BS2. Mark had a run in with the big sister and ended up in hospital.. and a whole bunch of other stuff..
I'd say that Mark will end up in the game as some one that helps you through rapture or maybe out of rapture.. anyway.
https://www.sau.com.au/forums/topic/283054-bioshock-2/#findComment-4765268
  • 4 months later...
I'm getting a copy of this. Only played a few mins of the first one but was good. Still playing borderlands at the moment.
is borderlands any good, I've read plenty of reviews and gameplay footage...
But still don't know if its worth it...
https://www.sau.com.au/forums/topic/283054-bioshock-2/#findComment-5030023
I've been watching trailers for bio shock 2 and I cant wait. It looks goooooooood. :D
I've play Borderlands a fair bit. Its alright but it can get boring. There are millions of guns. I spent more time building up my arms then shooting them.
Worth a go if you have time to burn. Plus co-op mode is pretty fun.
https://www.sau.com.au/forums/topic/283054-bioshock-2/#findComment-5031621
re: Masseffect 2 i got this email today..
Dear Sam,
Thank you for your application,
Please head to Masseffect2.com.au for a more detailed briefing
And remember, we kill because we care
Yours Sincerely,
Commander Shepard
https://www.sau.com.au/forums/topic/283054-bioshock-2/#findComment-5034509
I was watching some updates for mass effect, at least one of the characters has an aussie accent, last time I played a game with aussie accents was halo, is it the new 'nondescript international accent?' for games or something?
ie; like when hollywood forces their actors to do terrible british type accents to make their movies 'continental'
https://www.sau.com.au/forums/topic/283054-bioshock-2/#findComment-5037521
yo
you can preorder bioshock2 on steam its 10% off and you get bioshock1 free $71 USD
even better use the US store and its only $44 USD
US store link
http://store.steampowered.com/?cc=us
jsut change your address to USA then change it back
NY post code is 10001
https://www.sau.com.au/forums/topic/283054-bioshock-2/#findComment-5044721
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
